Thread: Masking Tape
    Default Masking Tape
    Can anyone recomend a good quality masking tape , that will produce good clean lines between base coat colors ? Thank you , Mike
    3,514
    3M makes a vinyl tape that is specifically designed to make a hard edge between color coats with no creeping, or bleed through. You can get it on ebay, but you may want to go to an automotive paint store.
    Aug 2012
    Kitsap County WA.
    5
    Yep 3M blue vinyl works good for that. Go to the store and get one that is still sealed and no dust on it. Fresh tape makes a difference!
