Results 21 to 30 of 36
Thread: My grandfather's 1916 Indian Power Plus coming back to life
  1. #21
    Hello All,
    Here is a picture I just found that shows the bike working on the farm.
    I am not sure when it was taken, but it shows the bike without the light and after the brakes were modified.
    Regards,
    Stephen
  2. #22
    Aug 2009
    rural eastern South Dakota
    934
    looks like he's hauling in a sack of spuds and a small barrel of milk?
  3. #23
    Quote Originally Posted by Grampa1916 View Post
    Hello All,
    Regards,
    Stephen
    That's a great picture, Stephen. Thanks for sharing it. As far as the muffler, mine also had a layer of baked on grease coating it. I left it that way. I think the leaky transmissions is the thing that preserved these old mufflers!
    Good luck.
    Kevin
  4. #24
    May 2016
    Melbourne, Australia
    24
    Oven cleaner will take the grease and oil off, just be careful to use in a ventilated area and dont get it on paint you want to keep! With a total loss oil system (i.e. the oil in the motor is burnt or mists out the exhaust rather than scavenged back into the oil tank for reuse), the muffler will soon get a fresh coating of oil again with the motor running.
  5. #25
    May 2011
    124
    Quote Originally Posted by Ross View Post
    I too like WD 40 but in time it evaporates. it is not aggressive to original paint and finish. I have also used trumpet oil with great success, the stuff your kid uses in band class. Both of these after a good cleaning with soft soap and warm water and dried by soft clothes very well. Nice bike, you are extremely lucky to have such a family piece.
    the museums over here said stay away from crc wd40 etc as while it evaporates there's a residue left, i have an original paint 1918 henderson;i don't use anything, it doesn't deteriorate in my shed whatsoever try that approach first while others comment. even if i'm out in the rain it dries off and any new rust is 'dusty' and will wipe off with a cloth.
  6. #26
    Quote Originally Posted by jellywrestler View Post
    Thank you, Jellywrestler,
    It is doing fine in my garage without anything, so I will leave it that way for a while.
  7. #27
    Default Rear Brakes
    Hello,
    I just removed the rear wheel and opened the brakes.
    My grandfather changed the linkage for the brakes and was only using the outer band for many years. You can see the linkage in the working bike photo I posted eariler.
    It looks like the brake drum is worn down on the outside and grooved on the inside. The bearing races have reduced the spacing causing the brake parts to rub on the drum.
    It looks like there is a grease shield inside the brake that was missing from Shaky Jake's rebuild.
    I was able to find a rear bearing kit from Ziggy in Canada, I am ordering them this week, but I have not found a new brake drum. Does anyone know where I can find one?
    Thank you,
    Stephen
  8. #28
    Hello,
    Thank you,
    Stephen
    Stephen,
    I got my brake drums from ZOC (Ziggy of Canada). I may have gotten one of his last ones. I got the cups, cones, and grease shields for my bearings from Walker Machine. The balls are available from McMaster Carr, I think they are 7/16 inch but measure an old one before you order.
    Kevin
  9. #29
    The rear brake drums came in two versions, I have not tried to look up which is for what years. On one version, the outside brake surface was curved, the brake band would wear into the curve, thus keeping the brake band centered on the brake drum. The other version, the outside brake surface has “curbs” on both edges retain the brake band between them.
    It is interesting to see the front wheel speedometer ring gear from the Stewart #200 speedometer system still on the front wheel.
    It is also interesting to see a lot of the Splitdorf magneto/generator electrical system still there.
    The amp meter, battery box, fuse holder, taillight, and headlight mount.
    The two switches on the handlebars, one if for the horn and other is for easier starting, which applies some current to the Splitdorf magneto/generator top coil to energize the magnets more until the motor starts running, at which time the magneto/generator will support itself.
    It is hard to tell, but it looks like there is the later version of the switch plate with the two switches on the back of the tool box. The littler switch next to the bigger center one, is for dimming the headlight, you will find a coil of wire inside the switch box for that switch.
    Spacke2speed
  10. #30
    Stephen,
    Kevin
    Hi Kevin,
    Ziggy is checking to see if he has more than he needs for his machines.
    I am getting the cones & cups as a complete kit from Ziggy. He says it will have all the parts needed for the rear axle including the hollow and solid axles and the price was good.
    Stephen
