Page 2 of 14 FirstFirst 123412 ... LastLast
Results 11 to 20 of 134
Thread: Pretending to know what I am doing - 1947 FL
    Dec 2014
    76
    I do. There is a LOT of info in it.
    Jun 2010
    227
    Liam,
    Your 47 knuckle basket is nicer then my 47 knuckle basket.
    The 47 order form has a check box for fender light or fender plate for police bikes, they came both ways.
    The first aid kit was a $9.60 option in 47.
    http://www.caimag.com/forum/showthre...e-basket/page5
    Jerry
    Jan 2010
    st clair pa
    17
    Good luck with your project I'll be watching your progress.If you need any 5$ parts let me know.
    LUCKY AL.
    Dec 2014
    76
    Quote Originally Posted by 1950Panhead View Post
    Liam,
    Jerry
    Holy moly. You're not kidding, that thing was kind of rough. That neck! I'm not so skilled in frame work, so I talked to a buddy yesterday about bringing him mine. I'm a firm believer in having a strong frame to start from. (I'll weld a tab or bungs or something, but I don't have the talent for frame building and tube repair just yet. I mean, I would cut a frame, but it seems like stock-dimension bikes are more to my liking. And I wince when I cut things anymore.)
    Quote Originally Posted by gurka View Post
    LUCKY AL.
    Thanks, Al. If you have any $5 Knuckle parts, sign me up for them now. Progress will be slow, but I need to stay on my project or I languish. Last night I removed the rear wheel, fender, oil bag, and brake assembly. Tonight I can hopefully pull the front end. The seatpost seems stuck; I gotta look into that and see what's going on. The cracked frame might have something to do with that.
    After that it's degrease time... I think I'm gonna go buy a kiddie pool and fill 'er up with some kerosene.
    Jan 2005
    Vancouver Island B.C.
    436
    It's more correct and complete than the 47 knuckle basket that I picked up.
    Jan 2008
    449
    I would be ecstatic if I got a project as complete and correct as that. Nice find.
    Dec 2014
    76
    Well, it doesn't look like much got done, but I did.
    I ran the engine up to Paul and Joel at American Cycle Fab. I have early heads (small port), but everything else is 74", so I have this weird homemade manifold. Front head has a big ol' crack from exhaust port to guide, which is apparently common and fixable. (Whew!)
    I started stripping the bike so I can get the frame repairs underway. Man, it's slow going. I understand why guys chopped these bikes; there is all sorts of stuff bolted to them and the whole damn bike is a jigsaw puzzle that has to go together in order! I also have no idea how the hell a factory fender gets installed (front especially) without nineteen hands and banged-up paint. I'm glad mine's a bit crusty.
    I'm going to find a refrigerator box this week so I can line it and start scrubbing larger items in kerosene. (If I find a kiddie-pool, that would be best, but beggars cannot be choosers. Methinks all the seasonal summer items at Wal*Mart have been put away.)
    Now for the "please help me" portion. My damper rod is stuck in place. I tapped at it, and it didn't seem to budge. I don't like to be a roughneck if I don't have to, so I mixed up ATF and kero, and filled 'er up.
    Does anyone have any advice for me moving forward?
    Menomonie, WI
    1,193
    Nice bike - hope you took a ton of pictures. Getting that dampner rod out can be a challenge. You probably will not be able to save it. Stat soaking and them I use heat and a hammer. Worst case you might have to drill the center out of it from the bottom. Only the bottom 1 1/2" is a tight fit.
    Jerry
    Dec 2014
    76
    Jerry
    You guys are getting all the pictures as I take 'em.
    I'm going to let that damper set and marinate in the brew for a while. Ideally, I am imagining I tap the top a bit and it falls right out, yes? Is there a penalty for beating from the top as opposed to drilling from the bottom?
    I counted 32 balls that fell out when I pulled the springer. Is that the right number? Sixteen top and bottom?
    2,455
    Study this and you'll understand where it is stuck...
