Results 11 to 20 of 39
Thread: 1925 FDCB Harley-Davidson
    Oct 2016
    1
    back on the tanks, soft soldered the gas tank up with an electric iron. the iron was a little on the big side but it was all we had. holds pressure and good enough!
    Oct 2016
    1
    working on the gas/oil side and drilled 3 holes to beat out the dents with a wood dowelphoto 42.jpgphoto 41.jpgphoto 51.jpgphoto 47.jpg
    Oct 2016
    1
    working on the front wheel hub, painted and zinc phosphate all the parts, now lace the wheel up!
    Oct 2016
    1
    Ok, got the wheel back and i mounted the tire, the tires are the same for the front and back 450-18 with KH rims...
    Oct 2016
    1
    ok, got it up on the new build bench...
    Dec 2011
    Falco Colo.
    139
    great work. what lead-tin percent are ya using on the tanks?
    gww57.com
    3,769
    Nothing like getting a wheel finished, putting on the tire, and then putting it on the chassis. Looking good!
    Oct 2016
    1
    Hi GWW, i used 60/40 and a tinning paste flux and also ruby liquid flux, work well with an iron. i also just used KREEM in the tank to seal them all up. i have used the KREEM on a 45 HD tank 20 years ago and still looks good inside the tank!
    Oct 2016
    1
    I need help finding a new front rod, just found a crack in mine! anybody have one to sell?
    669
    you'll probably find one like Al did. fwiw, Al is exploring feasibility of having new rods produced. i am on Al's list. i want a spare set just in case...
