Thread: JD compression rates
    Default JD compression rates
    I know there are many variables and I don't know what internals are in my JD but can anyone tell me the normal compression rates for the JD? Mine started running bad and when checked I got 25 psi out of the rear cylinder and only 15 psi out of the front cylinder.
    Apr 2003
    Seaford, NY
    374
    Sounds very low. You should have at least 75 psi. Confirm your guage accuracy.
    Jul 2009
    Sylacauga, AL. USA.
    110
    My racer, runs about 55 to 60 lbs warm, with an original iron piston/rings and tapered bore, since I built it about 5 year ago. Try lapping the valves, and the intake housing.
    David Morrill
    Sylacauga, AL. USA.
    AMCA #15284
    Deadly Dave's Blog
    Sharing the Lost Stories of Early American Motorcycling.
    http://dlmracing.blogspot.com/
    1921 Harley-Davidson Model J Racer
    It will break a hundred, if you drop it from a plane!
