Results 1 to 10 of 18
Thread: Tool kit for 48 Chief
    Jan 2016
    135
    Default Tool kit for 48 Chief
    We have a tool box on the bike but I am curious to find out exactly what tools they had in it from the factory. Could anyone help me on this? Thank you in advance.
    Sep 2012
    Saltsburg PA
    354
    I forget where I got these pics (maybe ebay) but its of a 47 tool kit. While this is a great display item, if you like riding your bike you will want to outfit your tool box with a variety of specific modern tools and parts.
    Jason Z
    AMCA #21594
    Jan 2016
    135
    Thank you.
    Jan 2016
    135
    Jason, in the first picture the punch looks like it is for the chain and I really can't tell what is next to it? any ideas? spark plug socket?
    Nov 2008
    265
    Yes, slide that over the spark plug and use the wrench to remove it.
    Apr 2015
    116
    Hi,
    Here are two photos from the 1953 Chief CS61097 reference set. 1953 Reference Chief CS61097 A.jpg1953 Reference Chief CS61097 B.jpg
    Original tools are quite rare, and the tool bags are even rarer. From the tools bouncing around in the tool box, holes are chewed in the original tool bag within a few hundred miles. Even the new heavier-duty reproduction tool bags will have holes chewed into them within a few thousand miles. A piece of foam rubber under the tool bag helps reduce the chewing problem.
    Jan 2016
    135
    I sort of figured that is what it was! The other tool is a punch for the chain I think.
    Jan 2016
    135
    Yellow 53, the tool in the lower left corner next to the ruler, I can't see what it is.
    Apr 2015
    116
    Hi,
    RonH; you had to ask, didn't you? What exactly that tool is and exactly what is does is a mystery, but there is a tool mentioned in the tool kit list; in the 1950-53 parts book that it might be. The tool is #809007, and it is called a 'Frame Rear Fork Spreader (1950-1951-1952)'. I don't know why 1953 isn't included. Maybe it wasn't needed, or maybe it just wasn't included in the tool kit. The 1953 Chief CS61097 is one of the nicest original machines that had a reference photo set taken when the bike was fairly new (regular film photography), so I'm inclined to believe that it did actually come with the bike, in the original tool kit. I can see that the tool might be a spreader, but what did it do? Was it used to spread the hydraulic front fork axle slot, so that the axle would come out easier? Was it used to somehow spread the rear wheel assembly so that the speedometer drive could be removed easier? Was it twisted with the pliers? Was it hammered with the back of the monkey wrench? I really don't know. Does anybody know? Please reply to this thread.
    Jan 2016
    135
    Yellow53 Chief, Look at the picture Skirted posted of the tool kit for 1947. Do you know what the tool is in the far left side of the picture is? Could it be a punch for the chain?
