Results 1 to 5 of 5
Thread: 1912 carburettor identification
    Sep 2003
    Lincoln, England
    62
    Default 1912 carburettor identification
    I Have just picked up an early '12 twin motor with a carb and unusual plate riveted to it. The script appears to say Model - K and then a stamped SR and underneath is the word HEITGEI. Can anyone identify the carb or know of the plate? thanks.
    Ian Biddle
    www.f-head.com
    It's a Heitger carburetor. Probably should have a clear glass bowl. Heitgers were supplied as standard equipment on a few brands of that era and were also available as replacement carbs for many others.
    They are rather rare. Too bad the bowl is missing.
    Mark
    Jan 2007
    Corvallis, Oregon USA
    688
    A google search for carb images. Bill in Oregon
    https://www.google.com/search?q=%22h...GKCmMQ_AUICSgE
    Bill Gilbert in Oregon
    Sep 2003
    Lincoln, England
    62
    Thanks, I've never heard of that brand before. I also have the top of the bowl, the valve and the float so I should be able to make the rest of the bowl (but not in glass)! Thanks again.
    Ian Biddle
    www.f-head.com
    Jan 2007
    688
    Be aware that the original float will probably be challenged by modern fuel.
