Results 1 to 2 of 2
Thread: 1910 Advance motorcycle
    Sep 2007
    Wis
    365
    Default 1910 Advance motorcycle
    Does anybody have a photograph or any other info about the Milwaukee made Advance motorcycle from 1910? I believe only a handful were made.
    Dick
    Sep 2007
    Wis
    365
    Believe it or not I just obtained an original cabinet photo(5x7)of an Advance motorcycle. And not from a contact from this posting. Talk about luck. Single cylinder, solid fork, unusual gas tank and frame, battery ignition, belt drive, inlet over exhaust and with a rider. With a large "Advance" on the gas tank. And this is not the British Advance. Very, very detailed but a bit faded. Engine looks to be a unique design. More research to follow. Will publish the photo when done. I may even be able to ID the rider. If anybody has any info I would love to talk with ya.
    later
