Results 1 to 10 of 12
Thread: Kreem Removal
    Sep 2013
    18
    Default Kreem Removal
    Does anybody know of a way to get old Kreem tank lining stuff safely out of my fuel tanks?
    Apr 2003
    Seaford, NY
    374
    Fill the tanks to the top with MEK. After a day or so the liner will be dissolved and be loose. You will have to protect the paint.
    Oct 2013
    Maryland
    278
    Acetone also works well. Dale
    Sep 2001
    United States
    466
    I used PAINT REMOVER and a small (to help loosen the sealer) chain on another brand of tank sealer. Of course... you have to be extremely careful not to get any on the outside paint. I taped the whole area around the fill cap to help protect it. NOPE... I didn't get any on the paint and it worked.
    Jim
    AMCA #6520
    Dec 2010
    Lamoille County, Vermont
    1,147
    Lacquer thinner, acetone, MEK (if you inhale it too much, you'll have three-headed kids), paint remover... lots of solvents.
    That stuff sucks. It's not that it doesn't work. It's that getting a tank clean enough to get it to stick is an industrial process and if you try it at home, Al Gore will send you nasty letters.
    If you can 'immerse' the tank for days at a time in a good solvent, you will probably get it clean. We send gas tanks (mostly old cars) to Canada. No EPA means great chemical processes and Weird Al can't complain.... So if you want, I can take it up with my next load of tanks and get it sealed properly. Not expensive for a bike tank. PM me.
    Cheers,
    Sirhr
    Sep 2013
    18
    Thanks for all the advice. I'm going to try the MEK first.
    872
    Apr 2010
    1,112
    At Bonneville they have discovered Nitromethane removes it in a hurry
    Dec 2001
    Low Country South Carolina
    148
    I am going to remove a sealer from my tanks also. I bought some Acetone and also bought some lacquer thinner as I use it as a universal solvent. Well to my surprise, when I got home and read the label on the lacquer thinner it said "100% Acetone. Looking at several MSDS for lacquer thinner showed they contained acetone, MEK alcohol and other materials. I dont know if this is a new developement or not as I have used lacquer thinner for years and never knew it contained acetone.
    Sep 2013
    18
    Well, it's been five days and the MEK seems to be working, although taking it's time. I suspect if I had a way to agitate it there would be quicker progress. There is a huge expansion of the liquid at different temps. Like huge!!! The paint is not original so the expansion didn't bother me, I knew paint was needed. Will keep at it. Yeah!! A '65 Panhead!!
