Results 1 to 7 of 7
Thread: Help Identifying Parts 1
    Apr 2013
    199
    Default Help Identifying Parts 1
    Can anyone help me identify the following parts which I believe to be Indian .
    thanks
    Dec 2010
    Lamoille County, Vermont
    1,147
    Dynamo and dynamo bracket also look like late 1930's or 1940 Chief as well. Bracket looks a lot like the one on my '38.
    The "Yellowish" bronze carb looks a bit like a Schebler HX.
    Cheers,
    Sirhr
    Is there a number stamped on the top of the carburetor? It has a Harley JD intake manifold attached to it.
    Mark
    Dan
    The indian generator that you have are trying to identify to use or to sell.
    I am looking for a suitable generator for a 1940 Chief restoration that I am doing and can't find one anywhere.
    I am 3 years into the restoration only to find that the generator I have is the wrong rotation and is off a scout.
    Let me know if you want to sell more than happy to to pay a reasonable price.
    regards
    Mike
    Apr 2013
    199
    Mark and others,
    Thanks for the replys. will check the carb for additional numbers but first glance didn't revel any. Sirh and Mike do you know what model generator this may be ? is it exclusive to Indians? haven't decided what to do with them yet.
    thanks for all the help,
    dan
    Oct 2011
    479
    The generator bracket has four cap bolts which is for a plunger frame,and a cutout so my guess is 40-47.
    Dan
    There would have been a band around the brush end that would have identified the generator model.
    The bracket as Tom stated is a 4 bolt bracket which first came out with the spring frame Indian Chiefs in 1940.
    Prior to that the the bracket cap was a 2 bolt item.
    Are there any numbers or serials on the top of the cutout.
    Can you post a photo of the cutout so that I can have a closer look.
    Mike
