Results 1 to 2 of 2
Thread: 37 and 47 valve guides
    ca
    160
    Default 37 and 47 valve guides
    Does anyone know if the 47 Chief guides will fit the 37 engine. Gerry Greer has different numbers, so there must be some difference., but what. I need to go through my 37 someday, and there are some guides on ebay for the 47 Chief. Thanks stan
    Oct 2011
    479
    Quote Originally Posted by stan View Post
    They are different.
    The 37 has two less fins under the seat so the machined smaller diameter that goes in the cylinder is shorter,more guide exposed.
