Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: 69 xlh motor question
  1. #1
    Default 69 xlh motor question
    I am currently rebuilding a 69 xlh motor . This is my first xlh and not familiar with oil line connections. What is the port at 7 o'clock to the rear exhaust cam and what type fitting does it take
  2. #2
    Jul 2002
    5,464
    Pictures?...
  3. #3
    Jun 2009
    PA
    151
    This is a 69 ch motor, the feed and return are the same as the H. Not sure which one your looking for but the left is the feed the right is the return. Check your parts book on the fittings I think they are the same as what you see here, but I'm not an H man.
  4. #4
    Quote Originally Posted by murph View Post
    The cases I have the port is at the lower left 7 o'clock to the rear exhaust cam and is threaded at an angle 1/8 npt
  5. #5
    Jun 2009
    PA
    151
    Pictures are everything, post some so we know exactly what your talking about. I'm not sure what your getting at.
  6. #6
    Jun 2005
    Northern Colorado
    837
    Are any of the oil lines as small as 1/8" ?
    VPH-D
  7. #7
    I will take a few pics and post soon
  8. #8
    Aug 2004
    Beautiful Northern New Mexico
    2,794
    Only the feed to the top end.
  9. #9
    Default Pictures of oil fittings go
    Quote Originally Posted by Rubone View Post
    Picture of oil port location not sure what the one at 7 o'clock to the rear cam and what is the proper fitting for there. also the breather is slightly off the mark when timing marks are lined up
  10. #10
    Oct 2013
    Maryland
    278
    For what it's worth- my '67 XLH has an 1/8th pipe plug in it, but it is nowhere near a stock bike. Dale
