Page 2 of 16 FirstFirst 123412 ... LastLast
Results 11 to 20 of 155
Thread: 1917 Powerplus
    Dale - on my Dixie magneto the 42 degrees is stamped on the drive side, not on the arm. I thought the Bosch mags were that way also, for example here is a link to one on ebay: http://www.ebay.com/itm/351244975569...569%26_rdc%3D1
    The Splitdorf mag/dynamo's come up occasionally on ebay, but they are apparently very precious.
    Kevin
    3,677
    Dale, here are pictures from the 1916 Indian catalog supplement. Somewhere, I have some Indian literature that shows the Splitdorf retrofit kit that used the Splitdorf DU5 generator, and Splitdorf magneto for electrifying earlier non-electric models, and replacement of the mag/dyno unit. As Kevin mentioned; the Splitdorf mag/dyno units are very rare, and very expensive, and usually don't work. Gene Harper recently rebuilt one and said they are quite a challenge. The retrofit kit would be the way to go, and would be period correct if I could find that literature. . . I'll keep looking.
    Mar 2013
    Queensland/Australia
    96
    Here is a Bosch 42 degree mag/dyno if it is of any interest. http://www.ebay.com.au/itm/Veteran-B...item1e96240ef8
    Cheers Steve
    1914 P&M
    1915 Indian (project)
    1930 M50 Panther
    1958 M35sport Panther
    Oct 2013
    Maryland
    233
    Great info! Thanks everyone. At least there are options. Had to go out and check the drive side of the mag. No marking except the 1 & 2. So does anyone have an opinion on whether this was running with this mag? Dale
    Mar 2013
    96
    It is my understanding that they will run with the wrong degree magneto. It just means that with one cylinder correctly timed the other will be 5 degrees out.
    I would want to have the correct degree magneto even though they will run.
    Cheers
    Steve
    1914 P&M
    1930 M50 Panther
    Oct 2013
    Maryland
    233
    Thanks for the response, Steve. I agree, I would want the correct one. I was just curious if it would have run because it looks like the mag has been there a long time. Dale
    Painterdale
    On you PP, that is a tool box with the Indian script latch is on the left side which now has a fuse block on its lid, not the battery box. Your battery box is on the right side just above the sidecar mount bracket. The Eric Smith’s literature shows the battery box on the left side, but the tool box and battery box can be mounted on either side. The battery box is notched along the top of the backside for the wiring and has a vertical rod that keeps both the side door and the removable lid locked in place. Remove the locking rod and the side door opens up and the lid come off for easy battery replacement. On the inside of the door on the tool box there should be a list of the tools that come with the motorcycle from the factory. I still have a tool box which has that list inside it, in a box of stuff somewhere in my garage attic.
    I use to tour my 1914 Indian with two tool boxes and not battery box because that allowed me to carry more tools and spare parts. Because I mounted gas lights (and used them), I did not mount my battery boxes. If you are going to be riding you PP a lot on public roads, a working battery box (electrical system) is useful for powering a brake light, keeps you from getting pulled over a lot by the Highway Patrol for no stop light ---- do not ask how I know this ---- not easy to have a gas powered brake light.
    As far as not having a luggage rack, note the extensions on the rear axle. These are for mounting a tandem (passenger) seat. Most tandem seats would require removal of the luggage rack.
    As far as the Splitdorf magneto/dyno unit, I have seen them on Excelsior (45deg) and Indian (42deg). I have seen people running them on tours with no problems, they were in good working condition and adjusted correctly. I still have one of those Splitdorf mag/dynos in a box of stuff somewhere in my garage attic.
    There are two versions of the Splitdorf switch block on the Indian supplement that Eric Smith showed, the early version does not have and the later version does has an on/off switch for the horn, so back then, kids would not be able to honk the horn by just pressing the handle bar switch.
    The electrical end and cap on the taillight wiring is not the correct Indian taillight version.
    ABC Generator has a battery and a non-battery system for electrical lighting also. Their early Indian version mounted on the tube below the gas tank and above the linkage boss on the front down tube. On the Indian, they would require a pulley mounted to an extension off the motor sprocket nut. In the Iron Redskin, there is a picture of two Hedstrom Indians on a mountain pass with ABC generators mounted.
    Hope some of this will help
    Spacke2speed
    3,677
    You can see the ABC generator in this picture. Not intended for use with bellbottoms
    Quote Originally Posted by Spacke2speed View Post
    ...As far as not having a luggage rack, note the extensions on the rear axle. These are for mounting a tandem (passenger) seat. Most tandem seats would require removal of the luggage rack...
    Spacke2speed, you sir are a wealth of information as usual. I wondered what those extensions on the rear axle were for. The passenger seat makes sense.
    Dale, are you going to restore this one, or just fix it and ride it? Or just bring it out in the light and admire it on sunny days? I'm jut curious; the bike would be well suited to any one of these options. On my '16, since it will be a rider and not a 100 point restoration, I'm considering retrofitting some old or reproduction tail and headlight housings with LED bulbs, and then just running a total loss battery system that can be recharged overnight when the bike is parked.
    Kevin
    Oct 2013
    Maryland
    233
    Wow! Fantastic! I knew this would be the place to get educated. Spacke2speed, I have to agree with Kevin, you are a wealth of information. It makes sense about the tool box, judging from the small bits and pieces I found in there. Inside the door is a bit of paper that you can read "company" on. I feel a little better about the taillight connector because one day while rolling the bike around it got caught in the spokes and broke. Oops! Brittle little piece. If you should decide that the mag-dynamo ever needs a new home please keep me in mind. Kevin, I definitely don't want to restore it. I want to get it in operable condition and I like to think I would ride it but I also like to think I ride my other bikes, too! Dale
