Thread: Henderson Camshaft bearungs
    Jul 2014
    riverina
    28
    Default Henderson Camshaft bearungs
    Hi all,
    Does anyone have a set of camshaft centre bearing for a K henderson 4 that I can see the inside of to copy the measurements, or I could purchase? Thanks in advance Dale
    May 2011
    126
    http://www.hendersonkj.com/kjex/index.html if you have no luck here, i've just put my motor together so unable to measure mine for you sorry Dale./
    4,162
    It shouldn't be hard to figure out what you need, and you can make the bearing to compensate for wear on the cam. The center bearing on my KJ was cut on both sides, and almost through. The bearing was then broken in half so it could be assembled on the cam as it was being pushed through the case. The bearing was broken so that the jagged break would perfectly re-align when the 2 halves were put together.
