Results 1 to 10 of 15
Thread: My 36 Four together
    ca
    160
    Default My 36 Four together
    Here is a couple pictures of the 36 together. You may notice it has carbs from a 37. I could never get the 36 Marvel mystery carb to work. It seams to run ok with the 37 duals, and idles good. I am not going to mess anymore with the timing. I think it is as close as it will ever be. The motor runs very hot. I think that is common to the 36-7 motors, plus it is still fairly tight. The first time I had it running, about a year ago, it had a whining noise when I backed off on the power. I took the motor out and checked and reset the bevel gears. The clearance opened up on the gears for a reason, which I corrected. I was sure that was my problem. So I put it back together again. It still has the same whining noise when I back off. With the motor off, in gear clutch, disengaged coasting down a hill it still has the noise. that tells me it isn't motor related. At this point in time I am going to live with the noise. Time to start on another project. I took it to a street show in our town last night. There was around 50 different brands mostly foreign made. There were four Indians. The people really liked my four. Stan
    Vermont
    741
    Quote Originally Posted by stan View Post
    They have excellent taste then, very nicely done!
    Oct 2013
    Maryland
    278
    I'll second that! Love the color! Dale
    4,156
    You did a great job Stan. I think the '36-'37 Fours are beautiful machines and your '36 is stunning.
    Jan 2008
    480
    Very nice Stan. I try to do my longer rides at temps under 70 degrees or so. If it is warmer I try to limit it to shorter, 20-25 miles rides or so, and then a cool off period. After flushing the motor with oil changes at 50-75 miles 2-3 times in the beginning, I change my oil at 750-1000 miles with normal 45-55 mph back road riding. I also run it about a half to 3/4 qt high on the dip-stick. Oil is cheap, motors aren't.
    Apr 2003
    Seaford, NY
    374
    Stan, Excellent! You should be very proud of your accomplishment.
    Oct 2010
    Hawaii
    260
    The whine could be tire related. What type of tires are you running?
    I have a similar issue with my 39 knucklehead.
    Went to the Firestone all weather tire and these whine up to about 35 mph. At higher speeds it is barely audible, but when decreasing at 40 and getting into the mid 30's speed wise it becomes really audible. It can be annoying if your in traffic at the whining speed.
    Last time I'll use these and looks like Cokers for the next set.
    Fine looking machine!
    Aug 2006
    So Cal
    898
    Very nice machine Stan, well done ! Don't know how hot it is, but from just my experiences with my Henderson and riding with a couple others. They seem to run plenty hot, compared to the twins. If I git off my 45 and jump on the Henderson, man there is a big difference. I have also noticed surprising differences between Henderson's on the same ride ? many factors I guess, but interesting. I have had mine out on a hot day or two in the desert, not recommended :-) One time with Harry Sucher, but to my surprise. The four cylinders took the heat just fine, though as mentioned by others I try to avoid it. Good luck with yours.
    Dec 2010
    Lamoille County, Vermont
    1,147
    Wow... just wow.
    Cheers,
    Sirhr
    Apr 2014
    214
    Amazing, I love the Green Paint as a color choice!
