Results 1 to 9 of 9
Thread: 59 sportster seat post bushings
    May 2006
    Southeast WI
    179
    Default 59 sportster seat post bushings
    Working on a 59 Sportster. Bought a seat post kit from V-Twin. Question is the seat post bushings #18 in the drawing.
    When pressed into the frame all the way, they stick up above the top of the frame 1/8 inch. The plate #12 bolts down to hold them in. Seems to me they should be flush. However I never put one of these together before....Thanks for any instruction you can offer....RodSEAT.jpg
    yes, they should be flush. did you check to see if there is anything inside the tubes? a lot of sportster frames were repaired or reinforced in that area.
    May 2006
    Southeast WI
    179
    Hi Jerry...Thanks for the reply. The tubes are clean. The bushings are stepped down on the bottom and fit into a smaller
    diameter tube inside the frame tube. The shoulder on the bush prevents it from going in any farther.
    The diagram shows another set of bushings #17 on the drawing. These were not with the kit and I'm wondering if the were for the earlier frames. Worst case, I'll just use these bushings and turn them down a bit on top.
    Jun 2009
    PA
    151
    There are alot of things wrong with the vtwin set you are dealing with. The uprights are also higher than the roller that the seat tee rests on causing the tee to rest on the uprights not the roller, I would mill them down as well. As Jerry said you need to make sure the frame tubes are sqeeky clean. I just had an issue with this project with cleaning the tubes out. This is an original set in the pic for a referance.
    May 2006
    Southeast WI
    179
    Hi Murph... Thanks for the heads up. That what I need to know. Info from someone who has delt with repro stuff before.
    Mar 2005
    785
    Murph,
    I know it doesn't make sense, nut the parts book shows the parkerized top plate installed backward with the bent lip facing up and towards the front. What's that about?
    Bill Pedalino
    AMCA 6755
    That has to be a mistake in the book. I have never seen one installed that way on any original bike or in any period/factory photos.
    Mar 2005
    785
    I know - it doesn't make any sense. The graphic artist probably placed the piece upside down when he copied it to paper and H-D missed it.
    Bill Pedalino
    AMCA 6755
    2,683
    There are many incorrect assemblies shown in parts books for all models. Using a parts book as an assembly manual is a crap shoot and has caused much grief over the years. It is only one piece of information that should be verified by other sources.
