Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 69
Thread: 1942 WLA Bobber Build
  1. #21
    Jul 2013
    Vermont
    85
    Dry fit of the engine and tranny
  2. #22
    Feb 2010
    133
    Hello Alan,
    How hard was it to get 3 tubes to start into neck forging at same time?
  3. #23
    Jul 2013
    Vermont
    85
    Quote Originally Posted by knuckcrazy View Post
    Hello Alan,
    It wasn't bad at all, it was easily done by hand. Everything lined up perfectly afterwards as well. Not what I was expecting, especially putting my faith in an eastern block casting!
  4. #24
    Jul 2013
    Vermont
    85
    I've made a little headway, I've mocked up the dash and installed the cups in the neck
  5. #25
    Jul 2013
    Vermont
    85
    And I'll be finishing the tranny and starting on the rear wheel rebuild
  6. #26
    Jul 2013
    Vermont
    85
    Finally finished the tranny (that kicker is looking way to inviting) and installed the sideboards with the footboards for fitment. The rear hub is almost complete with spokes and a rim on the way. Fitting up the seat tee also, have to mount the u-bracket and lowered pogo.
  7. #27
    Quote Originally Posted by alanc48 View Post
    Alan,
    Did you weld or braze the neck casting? Can you provide more detail on the installation? Thanks.
  8. #28
    Jul 2013
    Vermont
    85
    Quote Originally Posted by Kozy View Post
    Alan,
    I tig welded it. It took some time because I didn't want the frame to get too hot. I initially was going to braze it but the new neck had a little too much space around the top tube. Once it's painted you'd have to look really hard to find the tig welds
  9. #29
    Did you use a through pin in the casting holes or just weld to the tube slide into them? Thanks for the reply.
  10. #30
    Jul 2013
    Vermont
    85
    I used pins on the casting holes
