Page 1 of 7 123 ... LastLast
Results 1 to 10 of 69
Thread: 1942 WLA Bobber Build
    Jul 2013
    Vermont
    85
    Default 1942 WLA Bobber Build
    I, like Eric, also have a build thread going on Buzz's forum. I'm building a Bobber around a 42 WLA engine and using some civilian and some military parts. At this point I am fixing a disaster of a frame that I got and the I will be back on track. I won't bore you guys with all of the pics, just bring you up to speed with a music less montage.
    Jul 2013
    Vermont
    85
    After photobucket finishes with their maintenance. Love the new name of the thread, the only thing I could post in the Legendary category would be Legendary screw ups.
    Mar 2013
    Lachenaie Qc
    33
    Quote Originally Posted by alanc48 View Post
    Now that is funny Al! Keep up the good work and you'll find yourself a nice ride!
    Bob
    '' The hurrier I go, the behinder I get ''
    Aug 2006
    So Cal
    893
    Very cool, give us mere mortals a chance to show what were working on. I am excited to see this, well done.
    Jul 2013
    Vermont
    85
    So I started with a set of 42 WLA cases
    Got my conn rods honed
    Assembled and balanced the flywheels, conn rods
    Jul 2013
    Vermont
    85
    Assembled the flywheels with the bearings in the case halves
    After getting my cylinders back from the machinist I lapped in the valves and assembled the valve gear
    Jul 2013
    Vermont
    85
    I then installed the piston and rings on the small ends and made sure they were square
    Piston clip installation tool, a must have
    Piston squaring plate, another must have
    Installing the jugs, had to be real careful of the piston rings
    Installation complete
    Jul 2013
    Vermont
    85
    Next was cam gear timing. I marked the lines on the gears with a white paint marker so they were easier for me to see
    I set the lash on the valves, threw the heads on with original gaskets sprayed with copper gasket spray, left everything loose, installed the intake manifold with a rebuilt M-88 carb, and here she is.
    Jul 2013
    Vermont
    85
    Next up was the tranny (I am 90% done with it! had a hell of a time finding the right shifter drum.) I am mainly using the manual and this build from another forum which has been invaluable http://www.sscycle.com/tech/viewtopi...45+trans+build
    I'm going to spare you guys the details and blow right through this
    First thing I did was clean everything up, chased the holes and made sure everything fit
    Clutch gear and bearings
    Installing the seal with the special tool
    Checking the endplay after installing the mainshaft and clutch gear
    I then installed the cluster gear and counter shaft, proper clearances were obtained by changing out the spacers after checking endplay. At this point I had taken this thing apart and put it back together about 20 times
    Jul 2013
    Vermont
    85
    And almost there, i still need to install the drum I just got along with the shifter forks.
