Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 61
Thread: The 1916 Excelsior
    4,046
    A friend of mine suggested I wrap up my restoration of the 1916 Excelsior. I ended this saga before because I lost some very important parts. I never did find those parts but I was able to replace them so the job moved forward. I had planned to do a lot more descriptive narration attached to the pictures but I have now decided that Confucius was right and pictures should tell most of the story. If there is anything that readers want to know more about, I will be happy to elaborate.
    Tank with door
    Tank with door reattached
    Tank in primer
    4,046
    Some sheet metal parts in process.
    4,046
    Frame before straightening
    Frame during straightening
    Frame straightened and stripped
    Frame painted and striped
    4,046
    Fork straightening
    Fork stripping and prep
    Fork painting, and striping
    4,046
    Front fender issues
    After a lot of work the fender was straight
    Then on to paint, and striping. The decal was a brittle NOS example but it worked out okay.
    4,046
    I went through both wheels, dressed races, replaced balls, re-laced, and trued, and finally stripped, repainted, and re-striped. Wheels can be the most labor intensive element of an old motorcycle.
    Brakes
    4,046
    From talking to Gene Harper, I decided to replace all bearings, and bushings in the motor, trans, and clutch. Also a complete valve job with new valves and guides. The pistons are cast iron originals and fit a bit loose but still well within spec.
    4,046
    Some of the miscellaneous things that came up. I had a later muffler so I had to make a reproduction of the earlier style. Again, thanks to Gene Harper for pictures and dimensions of the correct muffler. Mufflers for early motorcycles are probably the rarest parts you’ll ever try to find.
    This picture shows all the control parts layed out.
    4,046
    The carburetor, and intake manifold needed much attention. I trued the manifold to accept new PEEK seals.
    And made a core drill to minimize waste of the PEEK. . . Very expensive stuff.
    For whatever reason, the Schebler body I had did not perform well. Fortunately, I had a beautiful original finish body and it worked like a dream.
    4,046
    More miscellaneous pictures of the Ex. The first pic is of the starter sector gear. There was significant damage to the teeth so I made a new gear out of O1 tool steel.
