Thread: 46 UL oil feed pump rotor wont turn...
    Aug 2012
    27
    Default 46 UL oil feed pump rotor wont turn...
    Rotor on feed pump wont turn, soaked it in carb cleaner to clean it out some but still wont budge. Manual really doesnt say anything that helps as in maybe how to get it apart. thought about heating it up but not sure if theres anything in there that heat will destroy. wish I had some kroil... any ideas ?
    1,411
    Heat will kill the spring between the vanes in the rotor. If they are out the likely culprit is crap around the governor assembly. Try soaking it in solvent such as diesel fuel, acetone with ATF, etc. Carb cleaner isn't much use on rust and crud. Be patient, let it soak for a few days!
    Robbie
    Rubone Amca #2736
    Aug 2012
    27
    Will do, Thanks Rub.
