Carl's Cycle Supply Y-Pipe
I'm not really sure where to post this thread, so here it is....
I've been following the Carl's Supply ad in the AMCA Magazine and noticed that he now supplies a replica knucklehead/panhead Y-Pipe. It even has the correct wide saddle at the Y-Joint. From the advertisement, it looks very nice. Having seen his 1941-sytle muffler at Oley one year, it seems like he offers high-quality replica products. Does anyone know if Carl's Y-pipe has the correct bend? New OEM Y-Pipes are as rare as hen's teeth and require a mortgage to buy. The other replacement Y-pipes are bent such that the muffler projects at an inclined angle and the pipe must be corrected before being installed. It would be nice to avoid the necessary cut/weld or heat bending necessary to achieve the correct muffler angle if a new part with the correct geometry is now available.
Thanks..
Bill Pedalino
Huntington, New York
AMCA 6755
