Results 1 to 10 of 11
Thread: 1913 Harley Belt Drive Prototype
    Aug 2001
    GA
    1,252
    Cool 1913 Harley Belt Drive Prototype
    Interesting article in "Motorcycling" May 1913.......
    Louie
    FaceBook >>>Modern Antique Cycle
    YouTube >>> LouieMCman
    Make Plans to Attend the 9th Annual Southern National Meet May, 2018
    Denton FarmPark, Denton, NC
    http://www.amcasouthernnationalmeet.com/index.htm
    Oct 2007
    880
    Belt drive twins are the coolest, great photos. Notice the increased offset primary cover, they had to move the chain out further to fit the wide V belt and pulley. Graton and Night must have used a long engine main shaft for this application. Look to the center of the (chain drive style) engine case you can see the webbing in the sprocket shaft main bearing casting boss.
    joe
    Feb 2003
    High in the B.C. Rockies....
    5,353
    So that was a proto-type in '13 eh? It sort of reminds me of the earlier Spartan setup.
    Cory Othen
    Membership#10953
    Apr 2009
    the source of the columbia river.
    176
    well thats just as damn beautiful as it can get on a fine machine like that!
    Oct 2007
    880
    Are there any right side views of this bike?
    joe
    I found this original picture on ebay a few years ago. No shots of the right side. This picture is the same exact picture that was used in the Spartan ads. and if you look close its the same bike that is in the article that Louie posted. If it is a prototype, then it's a Spartan prototype. I doubt that they sold any of these conversions, and this bike was probably the only one built. Notice how the rear section of the frame has been modified for belt drive. It looks like they repainted the bike too, cause some of the pinstriping doesn't look factory. It must have been a major job to install one of these belt drives.
    Aug 2001
    GA
    1,252
    The article says it is from Graton and Knight Co makers of Spartan belts. If someone has a copy of the Motorcycle mag from May 29, 1913 maybe it has a picture of the right side?
    Louie
    Oct 2007
    880
    Notice the pedal crank has been rubbing on the back side of the cut out hole in the primary cover. The bike uses the chain drive style FreeWheel clutch drum without the sprocket and mounts the rear pulley on the back side of the clutch drum cover plate. The offset outward on the front chain must be a lot. On my 14 Cannonball bike I can't fit an O-ring Primary chain without it coming into contact with the rear drive chain. Maintaining the magneto certainly would be a difficult task. Very interesting.
    joe
    Feb 2003
    5,353
    I would have to dig for the date for this ad but I do have the info here somewhere.... http://www.antiquemotorcycle.org/bbo...hlight=Spartan
    Cory Othen
    Membership#10953
