Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: When Things Go Wrong!!!
    Feb 2003
    High in the B.C. Rockies....
    4,975
    Default When Things Go Wrong!!!
    Just the messenger... this is a thread brought to you by Slojo.....
    This exhaust valve head fell of at a traffic light while idling. The valve appears to have a black hard coat stem and a part number stamped on the stem by the keeper groove as an identifier the number is 56012. Does anyone know who the manufacture is?
    joe
    Cory Othen
    Membership#10953
    Feb 2003
    4,975
    Whoops..... I neglected to mention that we're talking about a '48 EL.... and that busted valve in the top of the piston is a horrific shot!!!!
    Cory Othen
    Membership#10953
    Menomonie, WI
    588
    Actually for dropping a valve that is relatively minor damage. It probably just locked the engine up. At RPM it is a totally different story. It never is good but the head is repairable and the cylinder looks undamaged.
    Looks like the engine was burning oil or running rich. One valve wasn't seating very good.
    I cannot help ID the valve but Rowe is a big producer of valve hardware.
    Jerry
    Aug 2006
    So Cal
    592
    My brother in laws Sportster did that at speed, 30 years ago. It's still in his shed, he has not fixed it yet.
    Oct 2007
    872
    I bought the bike about ten years ago and the motor already had been rebuilt . It has a Jim's main shaft sticking out with his name laser etched on the end. Although it ran well I never liked the sound of the motor, (to much top end noise) and figured eventfully it would come out for a rebuild and conversation to hydraulic lifters. The valve guides are Rowe but the valve has not been identified yet.
    joe
    2,264
    I'll be following this thread with great interest as I have to do the heads on my '48 motor. Is there a consensus on who makes the best valves, guides, and springs?
    Oct 2007
    872
    I have not experienced spring failure using stock springs. These are not Indy motors. The material fatigue with this valve must have been a faulty manufacturing process. Either the friction weld or the subsequent heat treat, I believe the heat treat machine/process is at fault. Typically these problems are caught during manufacturing and this valve probably slipped by Q.C.
    Heat treating valves is most likely accomplished by an induction heat treat process. "Basically", a valve stem is inserted into a coil and a high frequency charge of electricity is pushed through the coil for a few seconds exciting the molecular structure of the valve stem to a point where the metal lights up from friction (Atoms bouncing of each other) within the make up of the metal followed by a quenching process.
    I am not a qualified metallurgist !
    joe
    Sep 2007
    Jersey City
    1,511
    Joe, that is pure sex to a motor head!
    1,706
    I am haveing trouble viewing the pics Folks,
    so please set me straight:
    You blame the valve?
    Feb 2003
    washington state
    91
    At least that valve head didn't pass into the lower end..... that would have made a noise. Was it the valve that failed or did the valve spring fail and drop the valve onto the piston which then broke the head off the stem?
    Mike Carver
    AMCA #3349
    1908 Indian diamond frame single
    1925 Indian 74 Chief
    1947 Indian 74 Chief
    1947 HD FL
    1952 HD FL
    1956 DB34GS Goldstar Scrambles
    too many British to list
