Ditto on Cotten's floats!
Bob Selph
1933VC/1934LT Sidecar
1940 Sport Scout
AMCA#15215
Nick!
Tests for vacuum leaks that require the motor to be running often miss critical smaller fissures.
An absolute test is performed while your carburetor is removed:
http://virtualindian.org/11techleaktest.html.
The manifold flange should be ground to flat, and the carburetor's flange lathe-dressed, as this interface cannot be bubble-tested.
With carb installed, this seam, and the throttle bushings, may be inspected with an un-lit propane torch, although it will suffer the same lack of sensitivity as any other running test.
No vacuum leak is an acceptible leak.
I got my Rubber Ducky, hopefully will be able to work on the bike this week. A shout out to Cass at Deluxe Restorations in Dousman, WI, he had the "Ducky" in stock. He is following his passion and keeping our old iron alive
http://www.deluxehdrestorations.com/
