If you want to be technically correct, the brake "drum" is called a "brake shell" in all of the Harley parts catalogs, not "drum" at all. It really is important, in most cases, to own a reprint of a factory "Spare Parts" book for your model of Harley (they're basically "all" available), and refer to it often when writing here; that way, everyone has the same references when delving into problems like this. "Brake drum " is so universally understood that it doesn't matter in this case, but can u name a part, number 4359-29? (66010-29 after the 1951 parts change-over) and compare that with PN 66202-29.
