Panhead Tool Box Mount
I'm replacing the tool box mount on a 1953 FL frame. I have an aftermarket bracket that looks pretty good as well as the approximate measurement of where, on the bottom frame tube the bracket is to be placed. My question is which joints get welded. I would assume that the bottom joint on the bottom of the lower frame tube (parellel to the ground) gets a full-lenght fillet weld, as well as as the vertical (side) returns running up and around the bottom tube. Is there also an 'inside' horizontal fillet weld placed on the TOP of the bottom tube between the tube and bracket?
Thanks...
Bill Pedalino
Huntington, New York
AMCA 6755
