Results 1 to 2 of 2
Thread: transmission mounting plate and oil tank
    Sep 2010
    125
    Default transmission mounting plate and oil tank
    are the mounting bolts and nuts on the trans mounting plate for a 62 pan cad or parkerized? also are the mounting hard ware for the oil tank cad or parkerized? thanks for the help
    4,254
    Its all Parkerized axcept the spacers under the oil tank plate which are usually cad.
