Results 1 to 5 of 5
Thread: 1965 Pan speedometer overhaul advice
    Cool 1965 Pan speedometer overhaul advice
    Yesterday, while riding around doing pretty much nothing, I noted a loud, intermittent screaming sound coming from forward of the engine. At first, I thought it might be generator bearings, but I noticed speedometer fluctuating when noise was worst. Needle then popped off of center arbor, and is floating around in speedo. I will be replacing drive, cable, and would like to overhaul speedo at same time. It appears that the bezel ring is crimped to a flange on the speedo case. I have never tried to dissassemble/reassemble this type of instrument in the past, so I have no idea how to proceed. Maybe I am going into too much detail, but this original dial differs from what I have seen in reproduction speedos.The Harley davidson logo is not the bar and shield, but a block cursive underlined, hyphenated style. Anyway all help appreciated
    Feb 2006
    N W Ohio, USA
    572
    John Bordas rebuilt a few for me. I don't think very many individuals could do this themselves. Mike
    Hi, Is John Boordas in the US? Does he have website or shop? Thanks
    Mar 2009
    457
    John Bordas is in Wheat Ridge, CO.
    Phone: 303 420 4510
    You won't be dissappointed..!
    Dec 2009
    Mt. Sterling, Kentucky
    112
    Two words, John Bordas, he is the best
