Results 1 to 10 of 11
Thread: Harley LT Sidecar Step
    Jun 2009
    TN
    170
    Default Harley LT Sidecar Step
    I have been looking for a step for my 33LT project. I just found this step for a left hand car if anyone is looking.
    http://www.ebay.com/itm/HARLEY-INDIA...#ht_500wt_1339
    Bob Selph
    1933VC/1934LT Sidecar
    1940 Sport Scout
    AMCA#15215
    Jun 2009
    TN
    170
    Just finished. I will have it at Denton if I can get the handling issues worked out. Hopefully someone there can help.
    Bob
    Bob Selph
    1940 Sport Scout
    AMCA#15215
    Hey Bob, That's a sharp looking rig you have there what handling issues are you having? a common issue is the rig pulling to the right of which case that could be solved with a little bit more lean out of the motorcycle IF it is pulling to the right of the road.
    Chuck
    AMCA Member#1848
    2,264
    I'm prejudiced, but I think the '33 VL is hands-down the best looking VL. Gorgeous motorcycle and sidecar Bob.
    Jun 2009
    TN
    170
    Thanks for the compliments. The issue I have is the handle bars wiggle from side to side. It is hard to take one hand off to shift gears. As long as you have a firm hold on the bars it is "ok". I haven't gone to 3rd gear yet. I have the lean adjusted properly I think. Hopefully someone can give me some guidance at Denton.
    See you there.
    Bob Selph
    1940 Sport Scout
    AMCA#15215
    1,408
    Bob,
    The "head shake" could be several things. But if you know for a fact the steering head bearings are adjusted correctly, and that the tire pressure is correct, then clamp down the steering damper. All sidecar rigs will wiggle at lower speeds if the damper is loose.
    Robbie
    Rubone Amca #2736
    Jun 2009
    TN
    170
    I do not have a damper, only a ride control. I guess I am on now on a new search for a damper. I had someone tell me I could try tightening the head bearings a little tight and it may help. I think a damper would be be better solution Should tire pressure be higher or lower for use with the car. I run Coker 19x4 at 28lbs.
    Thanks for all your help, Bob
    Bob Selph
    1940 Sport Scout
    AMCA#15215
    2,264
    After Robbie mentioned the steering damper I recalled that my '51 required the use of the damper; and screwed down tight too.
    2,264
    Bob, I see that Steve has a complete steering damper @ VL Heaven.
    2776-30 steering damper complete, cadmium. Nice piece! $170.
    Jul 2006
    Central Florida
    735
    Quote Originally Posted by bselph View Post
    See you there.
    You shouldn't have THAT much head shake. Sidecar rigs naturally shake, especially on acceleration and deceleration. It is the nature of the very short-wheelbase "3-wheel truck." You are right in finding a steering damper and cranking it down. That will take care of most of the shaking. My '37 sidecar is pretty stable, but I can't take both hands off the handlebar without it starting a little shake, the develops into a lotta shake if left alone.
    Insure that your wheels are balanced. It makes some difference on a combination. And that your front tire is at least the same diameter, O.D., as your pusher (what the bike's rear wheel is called on a combination). A slightly smaller front tire can affect trail, a function of the angle of the front fork and the front tire's contact patch with the ground. Good luck!
