Results 11 to 20 of 32
Thread: 1913 Thor Model 13-W ... HELP PLEASE!
    Found this old photo of a bike that I tried to buy years ago. Don't have a picture of other side, but I suspect the clutch linkage is similar to Leitner's. This one is a belt drive, though. I think this is 1911. Small timing cover, open magneto, early style fork, small toolbox. In 1912 (I think) they went to the big timing gear cover, similar to my bike. If there is a Thor expert, or even slightly educated, jump in! I am WAY out on a limb here, and I can hear cracking.
    Feb 2003
    High in the B.C. Rockies....
    4,980
    It definitely looks close. Did you see my last post?
    Cory Othen
    Membership#10953
    Progress this evening: Removed the rock hard tires. I have a set of white buttons from Coker that will work. Took the muffler off, as the tin can portion has a huge rust hole in it. The end caps and guts are fine, so should be a relatively easy fix. It is 3-1/2" diameter, and just happened to have the right diam pipe in the shed. Straightened the rear stand. Pumped a bunch of Marvel Mystery Oil into the cylinder, etc, etc.
    Still need to mount the tires, replace the control cable/wires, replace one spiral, soften the seat, replace the fuel and oil lines (cracks), and check out the magneto. I am contemplating opening up the motor to have a look, but it has good compression. Still, I think it would be wise to see inside. I just talked myself into it, but that will wait for now. I am on a mission to figure out the clutch mechanism. Going to make the drive south to Mathew Smith's at Antique Cycle Works in Oregon tomorrow. He is a wealth of information, and has lots of old and new parts, as well as literature and photos.
    Quote Originally Posted by c.o. View Post
    Excellent! I hadn't thought of looking there!!! I went there a long time ago and tried to get in, and I couldn't. Forgot completely about the library! Thanks. Yes, looks like the white bike has the correct setup.
    In my search for Thor stuff, ran across this bike. Single tank, twin motor?!! No toolbox door! It says "A show-quality restoration was just completed in May, 2010. "Best Motorcycle" honors was awarded at the 2010 Newport Concourse d'Eleganse. Absolutely stunning!" Wonder who the judges were? Car guys I guess.
    Here is a link if you want to buy it! http://www.classiccars.ws/sales/1912thoru7/index.html
    And here is a picture:
    Here is what Shappy's should look like. From the Chandler auction.
    Sep 2001
    Palmerston North, New Zealand
    716
    Are these any good to you
    The two diagrams are out of Victor Pages book
    Peter Thomson, a.k.a. Tommo
    A.M.C.A. # 2777
    Feb 2003
    4,980
    Quote Originally Posted by silentgreyfello View Post
    No problem. It had me wondering and I had to figure it out for my own peace of mind...
    Tommo, I must have breezed right by those diagrams as I thumbed through Victors' book. Good eye!
    Cory Othen
    Membership#10953
    Quote Originally Posted by Tommo View Post
    Thanks Peter! I just got back from Antique Cycle Works. Mathew hooked me up with the castings for the linkage parts. He also sent me home with a complete assembly to use as a copy. I also bought CD's for the complete parts books and brochures. Also found a left spiral. He has a lot of Thor parts, both original and reproduction. Can't wait to get out to the shop tonight!
    Here are some pics of Otis Chandler twin in Orig Paint. These are the photos I needed!!! Have more if anyone needs them.
