Results 1 to 7 of 7
Thread: 101 Engine DGP18XX and Magneto/Dynamo Identification help
Hybrid View
  1. #1
    Mar 2011
    PA
    61
    Default 101 Engine DGP18XX and Magneto/Dynamo Identification help
    I bought this Indian Scout Motor years ago and am looking for any additional info on it or the Magneto / Dynamo that was on it. What I have found out so far is that the motor (according to the Oregon Trail chapter AMCA Indian Serial Number chart) is the following:
    1928 Model GEP/101 Engine Number Range – DGP100-DGP4317, Horse Power 6.61
    Description: 45” 101 Scout changeover year from sf Scout, mostly assumed 1929
    Here's what I think I remember that I was told when I bought it:
    The guy I got it from, I believe, told me it was used as a hillclimb or racing engine of some kind and told me the name of the guy's shop in NY (I think) that it came from. I just don't remember any of the facts...wonder why?
    The Motor has 1/2 inch stroker plates under the cylinders and the Magneto/Dynamo is a Robert Bosch Germany. The pics show all the detail of markings on the mag.
    Any Indian/Magneto experts out there? Help!
  2. #2
    Apr 2010
    Austria
    81
    Hi,
    your Mag looks if it is the correct Mag-Dynamo for Indians. to be sure you need to see if it says DVAR or DVBR on the top / drive side and the cam-ring needs to be correct for 42° (some camrings are marked on the surface that touches the mag - sometimes these are too worn to be read)
    I can provide you with more information on these mag-dynamos if you write a PM.
    You can find information in the forum of the German Veteran MC Club http://210277.homepagemodules.de/ as well as at http://www.magnetos.de/bmz/php_sites/home.php (also parts and repair service for these)
    These magnetos were also used on Super X Streaminers in the US.
    Regards,
    gsottl
  3. #3
    Mar 2011
    PA
    61
    Thanks gsottl, It is a DVAR. It was on the 101 engine pictured. Is it proper for a 1928 101 scout?
  4. #4
    Apr 2010
    Austria
    81
    Yes, DVAR is fine for 1928. Kent Thompson in Fitzwilliam NH has original parts for these. He will be at Oley.....
    Cheers,
    gsottl
  5. #5
    Mar 2011
    PA
    61
    Thanks! I actually know Kent very well. I will have to hit him up at Oley...
  6. #6
    Dec 2006
    1,038
    cant help with the mag. so how about some inspiration
