Results 1 to 7 of 7
Thread: Neck bearing races
  1. #1
    Feb 2012
    15
    Default Neck bearing races
    I installed a set of after-market bearings and races on a '56 Pan that i'm building, the bolt hole distance between the upper and lower trees for the upper tins are about 3/16" too wide, could anyone tell me the length between the top and bottom bearing when installed, any help would be greatly appreciated, Thanks Whitey
  2. #2
    Whitey, Did you replace the neck cups with after-market cups or did you install new bearing races in your original neck cups. If you replaced the neck cups with after-market ones measure old ones and new ones and compare. Perhaps the new after-market ones were machined to sit slightly taller out of the neck. If each after-market one is 3/32" taller you would gain 3/16" between bolt holes.
  3. #3
    Jul 2002
    4,254
  4. #4
    Feb 2012
    15
    Thanks for the info. I installed new timken bearings and cups, apparently according to Chris's pics., I have later model cups, I didn't have the old cups, the frame was pretty hacked up, the original neck was cut and had about 5 lbs. plate welded on and stretched out over 20 degrees, I guess now the only option I have is to knock out and replace the cups unless someone might have a quicker fix. Thanks Whitey
  5. #5
    Mar 2009
    457
    Sorry, there's no 'quick fix' other than to replace your bearing cups with the early cups.
    And if you have them, it's actually a pretty quick fix...
  6. #6
    if you can't find any 49-59 cups, call mark Blankenship(304) 697-1445 after 3pm eastern time. He is re-producing them...
  7. #7
    Feb 2012
    15
    001.jpgThanks for the help, I probably will have to make the call,it seems that no one repops the early cups, but I have a question on the length of the neck, does anyone know the exsact length, I'm posting a pic. so you can see where I'm coming from Thanks Whitey
