Results 1 to 10 of 15
Thread: Switches
    Default Switches
    I'm working on switches today thought I should share info[IMG][/IMG]
    what years cad plate ? what years do the lever have a circle in the center? [IMG][/IMG]
    1950 and later on left?[IMG][/IMG]
    one horn button has round mounting holes the rest are oval. I assume that the one on right is a damn Indian part![IMG][/IMG]
    clamps for accessories with external wires--turn signal/spotlamp switches[IMG][/IMG]
    I assume that the smaller holes were drilled standard switches and the one on left is a correct accessory switch[IMG][/IMG] did earlier models have smaller hole-I have several with smaller hole many with large hole
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]first 3 are thru bar wire --4th is accessory--last one wire horn
    [IMG][/IMG]
