Indianut,
Can you tell me what you use to measure the I.D. of the case races and rod journals?
I am looking at getting a dial bore gauge with 1 ten thousandths resolution or better for this - do you have any other recommendations?
Also, how about measuring the I.D.'s of cam bushings, etc...?
Wish I was closer to you. I am not looking for your virtual finger print, but if you could share some of those - watch out for's that would be great!
I know what you are saying about there being a lot of stuff to check and evaluate.
I scrapped my stock rods when I found a suspect crack with the mag machine - I was lucky enough to use the machine at work during off hours for a couple of minutes.
D.J. Knott
AMCA #10930
