Results 1 to 2 of 2
Thread: Amal 391/14
    Oct 2006
    5
    Default Amal 391/14
    I have an AMAL 391/14 carburetor that I picked up a year ago in Davenport and it seems to be N.O.S. I disassembled it the other day and found that the metering pin and clip that goes in the throttle drum is missing. I've looked around some on the net for a parts source for this little beast and have had no luck so far. Anybody have experience with one of these and where I might go to find parts for it? It is probably the same as some other AMAL's but I have no experience at all with these
    This AMAL looks like the L&L carb used on 1949 149/249 Indians but has the air cleaner body formed into the carburetor main casting.
    Thanks!
    Jul 2003
    Rocky Top TN.
    261
    try these guys www.walridge.com
