Results 11 to 13 of 13
Thread: mystery part and piston advice
    ca
    100
    Tim, How are you comming on your 36 four project? My 36 came as a rolling frame and no engine about 25 years ago. I accumulated all the parts needed to end up with a complete engine. I had the cylinders, and heads replated, and they look real good. The assembly of the motor was a struggle, but it's together now hanging on my stand. I just need to figure out how to remove it from the stand and put it in my frame without dropping it. I hope we are having fun. Stan
    Mar 2011
    Near Bristol UK
    55
    Hi Stan
    Thanks for the words of encouragement. My bike came as a rolling frame and dismantled motor. I am struggling for information on crank drilling (some recommend some say don't do it), exhaust push rod rockers, felt pads in the rocker covers.
    See photos of rockers 2 are new with larger cups?
    [ATTACH]P1000276.JPG[/ATTACH]
    Any idea on which push rods to use?
    Help much appreciated
    Tim
    Regards
    Tim
    '36 four. '44 Chief & sidecar. '28 Scout. '67 XLCH. '70 BSA. and a Guzzi...............
    ca
    100
    Tim Seams like everyone has a opinion on crank drilling. I opted not to. I was told if more holes are added in the crank less oil will get to the rear of the crank, and to the clutch bearings. I myself not being a expert on the subject relied on the Indian engineers and their wisdom not to add these extra holes. I needed a rocker, and I found Hendersen Precision made them. The felt pads came with the gasket set I got from Dennis young years ago. They are nothing but a piece of felt about 1/4 in thick. I can send a tracing of mine if you can't find them. You may even try Roy Davies he has a lot of stuff. Stan
