Results 1 to 10 of 11
Thread: '50 fl oil leak from sitting ?
    Dec 2003
    409
    Question '50 fl oil leak from sitting ?
    anyone have a link or info on a fix for the oil dumping out from sitting . read somewhere about a ball bearing check valve sticking . like to get get it fixed in the next week or so . thanks
    Sep 2007
    Jersey City
    1,511
    Go to the panhead site and search there knowledge bank. There has to be a dozen differant topics on this problem with pro resolve. Bob L
    196
    It is usually the check ball. Maybe dirt, maybe ring groove on ball or valve-replace or reface radius on valve, or maybe needs lapped. I use the method described in, I think, the original Easyriders tech tips where you arch weld a rod to a 3/8 ball and use this to relap the ball seat. I just drain the oil out of the cavity enough to get to the seat and use a small amount of fine compound and lap, clean, and lap several times. Clean cavity well with Q-tips. I'm sure some will disagree but I feel that if a small amount of lapping compound does go in the oil it is no big deal, to me a comparasion is a oil tanker spilling in the ocean, spill vrs volume. Anyhow, good luck.
    Feb 2003
    High in the B.C. Rockies....
    4,978
    Cotten makes a burnisher that I've had good results with.
    Cory Othen
    Membership#10953
    Dec 2003
    409
    Quote Originally Posted by c.o. View Post
    have a contact number or info on cotten ?
    1,706
    Sorry to get into this so late Folks,
    But let us consider a few things about our H-D ball checks.
    First, those of us who cut motorvalve seats know that a thinner seat seals better than a wide one;
    Lapping and cutters widen the seat, and leave a finish that is either the grit of the compound, or toolmarked with 'chatter'.
    An effective seal against oil must have a finish of mating parts that is smaller than oil molecules.
    Burnishing is a technique where a hardened polished surface is pressed upon the seat to smooth it, without removing metal. Thus no abrasives are needed, and no chips from a cutter are produced.
    It can even be performed with the OHV pump installed, and full of oil.
    But the tool is not cheap, and demand has me in the middle of producing yet another small batch.
    Interested folks should email me direct at liberty@npoint.net.
    Thanks,
    Liberty Motorcycle Specialties, Inc.
    118 N. Washington Street
    Lacon, IL 61540 USA
    196
    My suggestion has always worked for me, but this sounds like a preferred method. I'll be contacting Cotten. Thanks.
    Dec 2003
    409
    Cool sent a email out
    me too . sent a email out to 'em
    4,254
    I bought my burnishing tool from Resurrection Cycle.
    http://resurrectioncycle.com/
    Feb 2004
    Utah
    205
    Interested as to the proceedure for using the burnishing tool?
    Thank You.
