Results 1 to 4 of 4
Thread: 1968 Moto Guzzi swing arm play
  1. #1
    Default 1968 Moto Guzzi swing arm play
    Anybody know whats involved in taking care of a slighly loose side to side play in a 1968 v700 swing arm?
  2. #2
    Quote Originally Posted by Eddie G View Post
    Eddie--
    There is a big acorn nut on the outside of each side of the swing arm, if you take that off you'll find a pivot pin adjustment that has 2 holes and requires a pin wrench to move. They're usually rusted in place and require a bit of patience and a lot of penetrating oil, they're a fine thread. They should be snugged down evenly and backed off a hair when everything's freed up.
    As I recall, the bearings behind them have to be pulled out rather than driven out from the back, which may be a challenge.
    If you don't know about this site already, you should go here and all your questions will be answered.
    http://www.thisoldtractor.com/gtbend...oss-references
    You should also download the workshop manual here if you haven't already.
    http://www.thisoldtractor.com/gtbend..._downloads.htm
    I have a tool I made for the pivot pin adjustment that I can lend to you, let me know.
    John Prusnek
    AMCA# 2430
  3. #3
    Thanks John, I've been to the site & downloaded the manual just haven't had time to go through it due to work & building the topend on my chief. I thought that there was some adjustmentbut was not sure. This is my first Guzzi so i will be learning about it
  4. #4
    Aug 2001
    GA
    1,252
    Eddie, I'm sorry to tell you that your Guzzi is trashed beyond repair and that I will come a take it off your hands for a minimal price. Let me know when I can come pick it up, thanks.
    I've always wanted an early Guzzi, good luck with yours.........
    Louie
    YouTube >>> LouieMCman
    Make Plans to Attend the 9th Annual Southern National Meet May, 2018
    Denton FarmPark, Denton, NC
    http://www.amcasouthernnationalmeet.com/index.htm
