Page 1 of 2 12 LastLast
Results 1 to 10 of 20
Thread: Can't start Flathead - need help
  1. #1
    Nov 2011
    Milwaukee, WI
    26
    Default Can't start Flathead - need help
    I could use some suggestions. I’ve always prided myself in being able to get anything started over the years but I am stuck.
    I have a 1947 WL 45. Sitting for over a year. Pretty good shape, original condition. I haven’t been able to get it started. Here’s what I’ve done:
    Cleaned out gas tank (not much in there) put in new gas.
    Cleaned gas filter, not much crud, a little.
    It has a new shut off valve. I took it apart, followed fuel to carb to make sure it has flow. It does.
    It has compression.
    It has spark at the plugs (took each out and checked for spark) and points. Gap in each is good.
    Checked valve/tappet clearance.
    Battery is charged & lights (including brake light) work.
    Float in carb was stuck. Not any crud in bowl but float did not swivel on float pin/fingers.
    Now float works and float valve opens and shuts gas off. I don't totally trust this float though.
    Low speed adjustment is 3 turns out . . . I’ve tried to start it with 4 & 5 turns out.
    High speed needle is 2 turns out.
    When I kick to prime (tried 3 kicks, 4, 5) with full choke I get gas at the carb (I wipe it down with a rag ‘cause I’ve had small flames at the carb, yikes,). I kick with dist advanced (turned full clockwise . . . tried no advance, half advance, etc) I get a pop, sometimes a good loud pa pop.
    That’s it. Never a double or triple pop like she’s gonna catch. It’s been a month now, dang. I have to be missing something!!
    I’m getting gas when I prime it. So much that I wipe with a rag to prevent a flame there. My next step is to take the rest of the carb apart and check passages. I kind of anticipated that suggestion. Any other suggestions? Any help would be appreciated . . . thanks.
  2. #2
    Jul 2010
    Tuscola,Texas
    220
    You didn't mention spark timing, have you checked it? Also the small lobe on the points cam fires the front cylindar. Sometimes a motor with a lot of carbon build up that has been sitting for a long period will hold excess fuel in the carbon and not fire clean(that is my definition if it makes sense). If timing and all else is correct I would try drying the combustion chambers with compressed air.
    Kerry
  3. #3
    Dec 2006
    1,038
    do the plugs look wet? maybe the gas is not getting into the cylinders.
  4. #4
    Jun 2009
    TN
    172
    I have discovered that mine only needs 1 prime kick. If I do more, and like you said gas spills out of carb, then I have flooded it and I either have to wait or hold the throttle all the way open before it will start.
    Bob Selph
    1933VC/1934LT Sidecar
    1940 Sport Scout
    AMCA#15215
  5. #5
    Jun 2005
    Ohio
    859
    Have you tested your manifold for air leaks? Also have you tried a very small squirt of starting fluid to see if if fires up?
    Steve
    AMCA #7300
  6. #6
    Nov 2011
    Milwaukee, WI
    26
    Default Good Stuff
    WoW, Great imput. I will try it all.
    Interesting point kg . . . have never heard of that before (carbon holding gas), gives me another tool to use. You said the small cam fires the front cylinder, not sure what your point was with that??
    BTW, No I haven't looked at spark timing. Have to delve into my manual for the "how toos" on that.
    I've tried starting fluid Ohio (big squirt, not small one...shhh, don't tell anyone on this post but got a small fire with that one), haven't tested for air leaks though.
    rwm I've got the carb off and am going to make sure the passages are not blocked . . . make sure gas is flowin' to the cylinders.
    bselph, I've wondered about that. In the past I've primered the hell out of bikes with no prob. I may be flooding the bejesus out of it. Out of all the combos I've tried I haven't tried 1 prime, go figure...
    Now just have to find the time to get to it, let you know, thanks all!
  7. #7
    Jan 2003
    England
    504
    Dear Hardly, you didn't say if you had the bike running a year ago. What kg is saying is that you need to make sure the front cylinder fires when the small end of the timer cam is just opening the points. With the Harley wasted spark system, it's possible to get the bike running on either cylinder with no hope at all of ever getting the other one going. This sends you off to carburetor and other adjustments which just make things worse. I recently finished a rebuild, fired up the bike, ran it up the road and thought it was pretty soggy, found only one exhaust pipe hot, then had to turn the circuit breaker a large amount to get both cylinders firing. It happens. A possible tip after the bike failing to start is to give it a few vigorous kicks with the throttle wide open. This can clear it if over-choked. Good luck.
    steve@vlheaven.com
  8. #8
    Did you pull the spray nozzle out of the carb body to chech bore and bleed holes?
    Toe
  9. #9
    Nov 2011
    Milwaukee, WI
    26
    Both plugs spark but I never thought to check if I have a spark at the "small end"
  10. #10
    Nov 2011
    Milwaukee, WI
    26
    No . . . carb is on the bench - will do
