Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 76
Thread: 22JD Tear down!
  1. #21
    Sep 2007
    Jersey City
    2,004
    Tip: A TRW universal steering pump puller fits a JD generator gear perfectly and what is even better is that the tip that makes contact with the shaft has a ball bearing in it so the contact point doesn’t turn doing damage to the threads. I knew if I kept looking in that tool tower, I find something.
    Now for the next dumb question on this thread.
    Was the intake manifold on a 22JD nickel plated? I want to give one small piece to my chromer to see how he does with it. Yea, I know. No polishing. Next question has to do with the barrels. The intake nipples are too far gone to save as Pete had suggested leaving them be. I’ll keep soaking them for a few more days and little heat. Push comes to shove, I’ll cut them and crush them, a job I’m not looking forward to. I can’t get the exhaust guides to move at all. Anyone have an idea on this one. When you nickel plate the cylinders, how do you plug them. I mean I can put silicon on the thread surfaces to protect them but what about the bore? Thanks guys, Bob L
  2. #22
    Dec 2006
    1,276
    nail polish on the threads rubber stoppers in the small holes. home depot has the rubber stoppers. the guy doing your nickle work should have some paint called stop off. you can plate the cylinder upside down then you don't need to plug the bore. just make sure all your holes are air tight(that don't sound so good). you may not get the valve guides out.
    with your intake nipple plug it up and pour your liquid in the bore. that will let it sit against the threads.i have some pretty sh#$y cylinders and the all have the nipples out and no thread damage don't use a hammer.
  3. #23
    Sep 2007
    Jersey City
    2,004
    Rob, never thought about the upside down thing. I got coffee can of rubber plugs (widgets.com) including a set I use on Panhead barrels to plug them off. Do you know the tolerances for the exhaust valve guide off hand? There was no wear on the valve stems when I pulled them out. Maybe there’s no reason to pull them out. As far as the intake nipples go, I have a 1.750 impact socket for the old gun. I was thinking the same thing this afternoon. Put a plug in the nipple and pool the Kroil from the inside of the barrel. The reason I stayed away from the idea was that a intake nipple mates up against the end of its respective bore and I really didn’t think it was going to do much. Bob L
  4. #24
    5,216
    NO! It was electro-less nickle washed.
  5. #25
    Aug 2006
    So Cal
    894
    Thanks for posting, very interesting - good reading watching the progress. The knowledge on this site is awesome!
  6. #26
    Sep 2007
    Jersey City
    2,004
    Care to fill me in on what that is Chris?
  7. #27
    3,804
    Electroless nickel plating was invented in 1944. I've heard of flash nickel, but never nickel wash. When Harley refers to nickel, they mean real electro-chemical nickel plating over copper.
    Sep 2001
    Palmerston North, New Zealand
    936
    I'd have thought that 1922 would have had a parkerised manifold and nuts. 1919 was the first year of the painted handlebars and I'm pretty sure that is when the parkerised manifold came in as well.
    I've got more than one set of NOS cylinders and the finish on them is what I call a dull nickel finish (please bear in mind we're talking 20's cylinders here and not teens) and there is no sign of copper under the plating.
    When plating cylinders, especially used ones, the biggest difficulity electro-platers have is getting the nickel to take in the small cavities and at the base of the fins.
    Electro-less nickel is a phosphating process very much like parkerising and so long as the cylinder is turned in the solution to let any trapped air escape, will give you a finish that is so close to what my NOS cylinders look like that I don't think you will tell the difference between the two.
    Surely there's a chemist or electro-plater among this group that can explain this better than me.
    Peter Thomson, a.k.a. Tommo
    A.M.C.A. # 2777
  9. #29
    3,804
    I've had all of my Henderson and Indian cylinders electroless plated as that process gets the nickel deep into the fins. I had a set of Excelsior cylinders plated via the electro-chemical process and had trouble with rust. I've never seen copper under nickel on cylinders, and I know you wouldn't want that. I was referring to H-D's description of their plating for handlebars, shift gates, etc. Platers have told me that prior to WW2, they didn't have brightners in their nickel plating solutions, so nickel had to be buffed to be reflective. I've seen early engineering drawings of Excelsior parts that stated the finish should be "white nickel". I've also heard it called "gray nickel". Most all NOS hardware, and fasteners I've seen has been nickel only, and rarely over copper.
    Sep 2001
    936
    We use electroless nickel on our rebuilt Scheblers and the first photo shows just that.
    The second photo shows NOS Harley J model cylinders and I'm pretty sure you can see that the finish is not bright nickel.
    My money for the best results for these types of cylinders would be electroless nickel and one other benefit is that the cost of this process is very reasonable.
    A.M.C.A. # 2777
