Thread: Loking for info on Linkert M6BA carb
    Default Loking for info on Linkert M6BA carb
    Looking for some info on a Linkert M6BA carb I have. Believe it is a Beck reman 1939 to 1942 bonneville. What is the history on these? Wonder if I should put it on my 48 chief.
    Thanks Cube74
    1941 four
    1946 chief
    1949 arrow
    1949 scout
    1958 Indian (Royal Enfield) patrol
    In progress/ (2 1941 Sport Scouts, 1941 Chief, 1947 chief, 1948 chief, 1951 Warrior
    Jul 2008
    Richmond, IL
    128
    1939-1942 Chiefs (Bonne) M6BA 1¼" - I would think that it would work just fine, but I am still learning.
    Cotten, would likely be a good source of info.
    http://linkertcarbs.com/beck.html
    http://www.indianmotorbikes.com/reso...arbs/index.htm
    D.J. Knott
    AMCA #10930
    1,706
    Folks,
    I have encountered several M6SA Linkerts,
    but never a BA.
    (SA referred to the military fuel filter fittings.)
    Beck never made carburetors.
    I believe they were re-stamped for the aftermarket by L&L, based upon an L&L spec sheet for the M8SA.
    Knotthead's second link above is fairly accurate.
    The first is fraught with misinformation, and models that never existed.
    Virtually any 1 1/4" model Linkert can be applied to a Chief, if if properly prepped, and Chief guts put into it.
