Results 1 to 6 of 6
Thread: Panhead Hydraglide Fork Leg Covers-Cowbells
    Apr 2003
    526
    Default Panhead Hydraglide Fork Leg Covers-Cowbells
    I'm trying to sort some parts for 1950 Pan. I have early covers (1/2" square nut underneath for screws) in two lengths, the shorter pieces being 3/8" less in overall length. I had assumed the short ones were 49 and 50 parts, the extra length added in 51. I don't see any part number suffix for the stainless covers to indicate a change in my oem books.Can anybody verify that? Any opinions offered would be appreciated.
    Kyle Oanes AMCA # 3046
    Apr 2003
    526
    Anybody have an original unmolested 49 or 50 model to measure? The shorter covers measure 6'' of stainless, not including the cad plated mounting steel, which you can't measure with the fork panels on.
    Jun 2005
    Northern Colorado
    437
    I have several sets of covers which I've thought were 70s-80s. The OAL is 6 1/2", while the stainless part measures 6 1/4. They all have the spot welded square nut.
    Apr 2003
    526
    I think the progression on the fasteners is 1/2" square nut, 7/16" square nut, 7/16" hex nut, and finaly a spot welded rectangular piece of flatstock with radiused ends. Not that any of that matters as they can't be seen installed on the motorcycle. I'm just trying to decide if the short covers belong on my 1950 model.
    May 2007
    New Jersey Shore
    403
    my cowbells on a 50 stock setup are 6 and a hair under 3/8 top piece with the top piece it is 6 5/8th
    this was original as I was the only person to take this apart
    hope this helps
    Moose
    aka Glenn
    Apr 2003
    526
    Thanks Glen, and thanks VPH-D for having a look.
