Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: 1930-1936 v vl manuals
    Sep 2010
    18
    Default 1930-1936 v vl manuals
    Where can i find a shop manual to rebuild v and vl motors? I see harley has reprints of old books are these worth it does anyone make a good manual?
    Jul 2006
    Central Florida
    852
    Best one made is from VL Heaven in England. AMCA Senior Judge Steve Slocombe has endeavoured (English spelling there, eh?) to fill the gap with the manual that Harley never wrote: $50, airmail postage paid from England, last I checked. http://www.vlheaven.com/
    Sep 2010
    18
    i have that i meant a shop type manual for rebuilds.diagrams procedures things like that.
    1,060
    Hi Todd and my VL Restoration Book is all there is for this model. It does not repeat well known workshop techniques, but has procedures for most components specific to the VL. I've tried to make exploded diagrams for key assemblies, which were not available originally. If there is information you need which is not in the book, please contact me through www.vlheaven.com.
    5,068
    To my knowledge H-D never had a shop manual for the VL's. Riders Handbook and Shop Dopes is all there was. Parts and accessory catalogs were printed. Use Steve's book and live happily ever after. All you need for rebuild is the clearances and prior H-D knowledge.
    You can find reproductions of VL years parts and accessory catalogs at:
    http://www.replicantmetals.com/library.html
    Along with other parts for the early Harley's.
    The information you want is not out there. Steve's book is a bit of help but not technical enough for a gear head, machinist. Someone is making tools (for auction). We are making our own tools starting with the clutch and transmission. We will document everything you need to know in time but that won't help you know.
    1,060
    Dear John, I think all the known clearances are in my VL book, and I've guessed at some of the others. The Harley Shop Dope reprints contain several specifications of engine clearances and valve/ignition timing. Many VL tools have been re-made. The valve cover wrenches, tappet puller, pinion gear puller and wheel hub wrench are available from myself or Vintage Motorcycles Nothwest. I've made the gearbox X-tool and laser cut a less expensive version of the 2" manifold wrench, while Mark Masa has made a fine VL clutch puller which saves distorting the clutch drum with a three-leg puller. There are even plans to make the frame table with a big laser cutter, and that's serious. The VL clutch assembly jig is a possible needed item, but expensive if you don't use it often.
    Sep 2001
    Palmerston North, New Zealand
    907
    Your best bet is J.B. Nicholson's book Modern Motorcycle Mechanics but you will need to ensure you get a first or second edition because by the third edition a lot of the early info has dropped out in favour of the later stuff.
    First editions will be hard to find but second editions shouldn't be too hard as there were at least two reprints of that volume.
    Peter Thomson, a.k.a. Tommo
    A.M.C.A. # 2777
    Feb 2003
    High in the B.C. Rockies....
    5,353
    You nailed it Tommo. "Modern Motorcycle Mechanics" has proven to have info that in a lot of cases, can't be found elsewhere.
    Cory Othen
    Membership#10953
