Results 1 to 10 of 13
Thread: Indian Red
    Mar 2011
    Mpls/St. Paul, MN
    33
    Default Indian Red
    I've searched these forums quite a bit, and if this information is already out there, I couldn't find it. What is a modern paint code for the classic Indian Red? I also searched the interwebs and couldn't find anything all that concrete. Is there a modern paint producer that has something the similar, or even spot on?
    Dave
    And the Blue, too... Not sure which I want to paint my 14 with.
    Aug 2006
    So Cal
    898
    Really suprise no responses, Here's what Johhny Eagles recommends - Dupont Nason urethane 88191m code D. He and Chuck Vernon believe it to be correct and they have done alot of Indians over the years. Including many teen's bikes, anyway it's what I plan on using on mine. Hope to make progress this year on mine, I hope I hope :-) Good luck with your's.
    Feb 2003
    High in the B.C. Rockies....
    5,353
    I would think those guy ought to know alright Tom. So is it more of a crimson or the lighter colors that you sometimes see?
    Cory Othen
    Membership#10953
    Aug 2006
    So Cal
    898
    Yep, I would call it a darker Crimson - not lighter. It looks good on the old machines I can tell ya that. Of course I kind of like anything in Indian red :-) I wonder if it's kind of like my Henderson though, I tried to git the correct color. Ask a bunch of folks who know far more than me + several so called experts and ended up with a bunch of different opinions. Finally decided on Lord Blue and am happy with it, so who know's? All part of the fun right? I had some original paint on my deluxe, under the tool box, it was blue - but almost black. The Lord Blue looks black in any shade but out in the sun it's blue alright. Bob Stark sell's an Indian red, probably the other outfit's too. Though again, I wonder if it changed abit through the year's?
    Mar 2011
    Mpls/St. Paul, MN
    33
    Thanks for the info. It gives me a great starting point. I would have to think that it changed over the years, but who knows? I'll look for the Nason, as everything I read so far said it is a good quality yet inexpensive paint.
    Dec 2002
    270
    When I painted my 45 chief Indian Red, I got an Original Paint chip from Robin Markey, Took it to the PPG supplier & he Computer matched it, It is dead on nuts exact color, I did not try to find a modern color that was close, I'm sure Robin can get that for you he has Original Paint in Original Cans that's still good. Just my 2 cents
    Oz
    Mar 2011
    Mpls/St. Paul, MN
    33
    Sounds good! I'll look into that. Thanks!
    Sep 2011
    15
    RM brand paint is still around and the current mix number in UNO-HD, a single stage urethane, is 8609-A. Many of the old Indian non-metallic color formulas are still available and accurate. BASF now owns the old RM company and can quickly search their database for very old colors, car, truck, and motorcycle.
    Jul 2001
    508
    Quote Originally Posted by 45OZ View Post
    Oz
    use DuPont Centari 143AH, the color never changed from the first year (1904) until the end (1953)
    Kevin Valentine 13
    EX-Chief Judge
    Jan 2012
    Spain
    24
    hi kevin, i cannīt agree with you at all. perhaps the original color was the same for the first years, but sun beams + temperature changes changes it a lot. Untill the end of the 20īs or 30īs the color of Indian was different. when bikes where painted in the indian factory, they used a color that is like carnival red (if you have the possibility to see original color brochures about powerplus, scouts, early models,..., you can see in them that the red is very bright). in a few years, this color was weathered, and you can find old parts with the original paint and the red is very dark, like the red coach; i have found across my life lot of original parts, and the red is very dark. i have choose a red like the carnival for the restoration of some of my indians, as for example my1920 indian scout that you can see at the jerry hatfield book called "indian scout". i think it is a very accurate red, compared with old brochures. other bikes that i have, as for example my 1947 indian chief original paint, the red is totally different.
    a good information about paints is the pdf called Standothek "Prestige and Classic Cars" that you can find at http://www.standox.com/portal/en?pag...y=Classic+Cars
    perhaps i am in a mistake, and sorry because my english is not enough good to explain what i have in my head.
    enrique castells from spain
