Results 21 to 30 of 36
Thread: Harley 1910 Magneto Drive
  1. #21
    Dec 2010
    Lamoille County, Vermont
    1,147
    Here are some pictures of the throttle side as well as one picture from a later bike (mechanical intake single.)
    Sorry about the sideways post. Magneto link.
    This gives an outstanding view of the throttle link with a brazed on post. I *think* this is the original/correct arrangement for the lever. If anyone has a picture of a frame (or a parts book that shows the bits) it would confirm it.
    This shows the lever arrangement on a later single. I think a '15. It has a mechanical intake valve, much like a J. But the lever arrangement seems to be the same.
    Another view of the complete arrangement from the left. Note the brazed-on post for the throttle/compression release lever.
    Excellent view of the controls.
    These are the best pictures I have been able to find in my books. There is one other picture (I think posted earlier in this thread) of a bike owned by Fred Lange, from whom I bought the castings. Gorgeous bike, but the lever arrangement is confusing as it seems to be drilled into the frame. It's the only time I have ever seen that layout. So don't know if that was unique to that year or another way of adapting a battery bike to magneto.
    Thanks for everyone's interest and cheers, Sirhr.
  2. #22
    Dec 2010
    1,147
    After a couple of weeks waiting for parts and doing spring chores... (and working on the EL)... here is one picture of the carb mounted on the conversion.
    I'll have pictures of the mag mounting, carb mounting and controls in a couple of days.
    I ended up taking the motor out of the frame briefly. In retrospect, that's the best way to do the mag work. It has to come out anyway in order to put in the mag control tube.
    Now, off to cook Easter Dinner. Happy holidays, all.
    This shows the carb with its offset intake and mount, the top of the magneto (now final installed and timed) and the beginnings of the controls (which are a royal PITA.) But it's all coming together. The mag throws a hot spark. I'll get it running and tuned, then paint the tanks.
    Cheers,
    Sirhr
  3. #23
    Dec 2010
    1,147
    Last weekend, I made a lot of forward progress on the 1910 Magneto/Linkert conversion. Here are some updates for those following the progress.
    In retrospect, it's more involved than I thought it would be. But I didn't have anything to go on... and am winging the whole thing. But everything is straightforward and though there is some fabricating, etc. to do, the conversion should be well within the capabilities of a home mechanic. I have lots of cool machine tools to play with... but any decent fabrication shop/machine shop can make these bits based on photos and sketches.
    I am really, really looking forward to seeing how this runs. The setup should be really reliable.
    Based on where we left off, it was time to final set the timing and button up the magneto drive. I cut gaskets for the cam cover and installed the cam gear set. I used the timing method that was described in an earlier post showing how to ensure cam position was correctly set (this is called the Valve Timing -- as opposed to the ignition timing.) After ensuring it was in the right place, I locked the cover down with a gasket and sealant and fitted the cover (but without a gasket yet. We still have to set ignition timing.
    The magneto was set on at this point and it was lined up to ensure the gear teeth meshed perfectly (and in plane with) the gear train. This is very important. If the mag is caddywampus, the gears will not mesh right and will chew each other up.
    With the mag mounted, I set the ignition timing, again going by an old manual posted here. On the drive belt pulley, I made marks for Magneto Advanced Ignition and Magneto Late Ignition. I also put on a TDC mark for the piston.
    With the timing marks set, I final mounted the cover, removed the spark plug and ran the engine using a large drill in order to check the timing. The magneto fired beautifully and the timing seemed right on. I set it so that the MLI was firing just after TDC. The MAI was about 30 degrees BTDC. So with the grip control, I should have a lot of flexibility on timing. Not sure if this will be like the Curved Dash Olds I used to own... but that car was basically driven with the timing, not the accelerator. You kept the throttle open all the time and modulated the timer for power... interesting way of driving. I suspect this will be more advanced (pardon the pun.)
    With the cover in place, it's time to go on to carb mounting. Above you see it held roughly in place.
    With the Linkert M16, there is no room between the bowl and the magneto (and between the body and the 1910 fuel filter/fuel outlet under the tank. So it has to be set on a slightly offset mount.
    To create an offset mount, I used a Linkert intake (from a Servicar) and cut off the Y-pipe, then threaded an adapter to allow it to go onto the 1910 cylinder. In order to create the offset, the manifold was chucked in a mill and a boring bar was used to put in the adapter at an angle. It was then silver-soldered in place. It was final lapped into the cylinder for a tight fit.
    Above we see the manifold in place. Note that the bolts had to be put into place before the manifold was seated! There was no room between the flange and the fins. A couple of the carb mounting bolts had to be thinned as well. But all went in nicely.
    On the subject of clearance... I started doing this with the engine in the frame and the tanks on. No question that this job is much easier with the tanks off and the engine out of the frame. Competition Distributing sells an engine stand that I wish I had bought before starting this. Note that the engine comes out/goes in very fast. And the tanks only have a few fasteners. You will need to assemble/reassemble a few times!
    Back to the story...
    With the manifold in place, the carb can be mounted (at least temporarily). Make VERY sure that your manifold (and therefore your carb) will be level. If it's tilted, you'll never get your fuel float level right.
    Here we see the carb mounted showing the offset. This will clear my knee fine and looks very presentable with its brass barrel and aluminum float. But it still has to be connected!
    In addition, the level of the carb coming off the intake was such that the tanks on my bike had to be slightly raised. I wanted to do this anyway, because the side of the right tank actually touched the brass cover of the intake valve. That was unacceptable to me.
    So I made some blocks that went between the frame and tank, raising both tanks .250" allowing lots of clearance on the carb. Those pictures in a moment!
  4. #24
    Dec 2010
    1,147
    Raising the tank was pretty quick and straightforward. I started with some 1/2" aluminum plate and made some spacers for the frame.
    Here is one of the blocks resting on the frame, unmachined.
    Set up in the mill, the face is cut to exactly fit the 1.75" OD of the frame tube. A hole is drilled for the tank mounting screw.
    The block will fit in between the tanks and give .250" of height. There are cross bolts underneath the tanks, and they still clear the lower frame tubes fine.
    Here is the right tank attached, showing configuration.
    And here is the additional clearance. This was not just necessary for the intake cap, but for the carb, which needs room for the linkages.
    More on that in a moment!
  5. #25
    Dec 2010
    1,147
    The last series simply raised the tanks to clear the carb and intake.
    Next, we need to modify the Linkert choke lever to clear the fuel filter. This simply meant filing off some of the lever (marked in red) to clear the filter.
    Next, we need to make a new lever for the Linkert. As the original Schebler carb works in a direction opposite the Linkert, a lever has to be made to move the cable attachment onto the left side of the carb (looking from the choke end.) I made a lever from a flat piece of brass and added a rotating barrel through which the control arm can pass. The lever is somewhat visible in this picture, along with the springs to control the throttle.
    Attachment 6561
    Note the rod with the springs on it... more on this later. But this setup controls the throttle. The springs are necessary because the throttle controls both the engine speed AND a compression release. On the battery bikes, the compression release is handled by the timer control. Full retard (plus) and you get the compression release to open for starting.
    On the magneto bikes, Full throttle 'plus' and you get the compression release to work. So the linkage has to be able to fully open the throttle and *then* pull a bit further to raise the exhaust valve for compression release. More on this later.
    First, we have to start fabricating some linkage mounts and parts.
    From the pictures I posted earlier, it appears that the magneto bikes had a different frame from the battery bikes, with a mount brazed on for the throttle/compression release toggle. I opted to make a mount that looked the same, but hold it on with screws.
    First, a pedestal was modified to hold a rod. It was also cut to fit on a base. A tab was made that fit around the frame tube (1.75" ID and 2.00" od.) I used aluminum bronze, which is a very tough alloy and is easily silver-soldered.
    Here the mill is used to round the base of the pedestal so it will fit on the clamp/tab. The pivot for the lever is already test fitted in place pending silver solder.
    In the next photo we see the modified base after milling using a 2.00" cutter.
    Below is the finished bracket on the frame down tube. I opted not to braze/solder the mount on, instead screwing it to the frame w. 10-32 machine screws.
    Now we are ready to start fitting linkages... which will be next weekend's project. A couple more photos follow, however.
  6. #26
    Dec 2010
    1,147
    Here are some additional pictures of the linkage, one showing the lever that was made/mounted to the Linkert to control the throttle butterfly. You can see the barrel through which the control cable passes and which supports the springs.
    This also shows the lever that was made and attached to the top of the Linkert lever. With the throttle lever modified on the linkert, it works in the correct orientations with the 1910 throttle spiral.
    Earlier, I mentioned taking the engine out of the frame... and here is why. The magneto advance/retard control cable runs through a tube that is attached to the top of the engine -- this is a cap over the combustion chamber. The engine top also incorporates the top engine mount that is attached to the frame. To get the tube onto that bolt, the engine must be released from its mounts and dropped away from the frame mounting tab.
    In addition, the tab that holds the tube is over .100" thick. So the top engine mount has to be relieved to fit the tube. Here the hex has been removed from the engine, chucked in a lathe and .100" is being cut from the flange below the mounting bolt.
    This shows the bolt in position (outside its mounting tab) with the tube resting on it. That tube will not go on with the engine in the frame! Doom on me.
    This last picture shows the tab in place under the motor mount.
    Note that the above picture also shows the throttle toggle and bracket on the frame downtube. You can see the throttle linkage extending backwards to the top of the Linkert. And just make out the linkage that extends downwards to the compression relief lever.
    Now that all the linkage brackets and layouts have been set out, next weekend (weather permitting and the river don't rise) I can lay out and complete the linkages.
    Note, too, that the positioning of this front bracket (and the lengths of the linkage rods) are absolutely critical. There is a great variance in the sweeps of the arms... so to move the arm the correct amount to open/close the butterfly requires that the brackets be strategically placed. Hard to describe, but as you consider the arcs that the toggles/levers travel as they rotate, you see that distances can become critical. I have a huge amount of respect for those who designed/figured out linkages!!
    More to come and glad folks are enjoying this.
    Cheers,
    Sirhr
  7. #27
    Dec 2010
    1,147
    I got the linkages all in place and done today. But didn't take any pictures. But I'll post some in a couple of days of the finished linkages, which gives an idea of how to do them. The cables were 'barely' long enough... I should have ordered another set. But I just made it.
    Also designed an air cleaner (more of a bird screen) that I'll try and build this week. I need to put on a fuel line and the air cleaner and then I'll try and get it running. See how it does with the new components.
    Cheers,
    Sirhr
  8. #28
    Feb 2003
    High in the B.C. Rockies....
    5,353
    Sirhr, it sounds like you're making some good progress. Some shots of the finished product would be great! Video would be even better!!!
    Cory Othen
    Membership#10953
  9. #29
    Dec 2010
    1,147
    After changing the carb settings (I set it by memory... and reversed the number of turns on the carb jets... that's why I always read the manual) she started right up. Running rough and spitting a lot of gas out of the carb. But it ran and sounded pretty good.
    I will have some pix (and a video) when I get it tuned. But at least I know it will work.
    There was some 'squeaking' from, I think, the mag drive. It is very well lubed with assembly lube, but I don't think it's getting enough (or any?) lubricant. I need to address that. It needs an oil bath. Before I run it again, I need to pull the cover off and see what's going on. Some thin shim washers may be in order, as well, on the cover side. I don't like the fact that there were none specified and I think it should have something to keep the gears away from the aluminum cover.
    The engine also feels really 'tight'. It has lots of lube. But doesn't like to turn over, even with the compression release activated. But once it starts, it doesn't seem to act like a tight engine.
    Anyone have any recommendations for a belt dressing for leather belts? It definitely has a 'slippy' belt, which makes starting a pain.
    A couple of pix of the fuel line and bird catcher, etc.
    Bird catcher. Made with brass and a sheet of .064" german silver (plus a drill press...) Not authentic to anything... but sort of has that goofy Edwardian look and will keep fingers and large rocks out of the choke.
    This shows the full configuration.
    I'll post control pictures later. But she'es alive!!
    Cheers,
    Sirhr.
  10. #30
    May 2006
    Southeast WI
    179
    This is copy from a page of the riders manual...hope it helps...Rod
    1912 RIDERS MANUAL
    BELT Keep the belt clean by all means. If dirt, sand or dressing accumulates on the belt it should be removed by scraping with edge of a stick or with some blunt instrument. We recommend that the belt be dressed with castor oil. After giving the belt a liberal dressing let it soak in overnight. Do not let any dressing get onto the enamel of the machine or it will stain it. The belt should be dressed at least once a month.
    Never get any oil or gasoline on the belt.
    Run the belt as loose as possible without slipping and drop the idler every night. This gives the belt a chance to shrink a trifle.
    All belts are stretched on the jack before they are put onto the machines and will not stretch much more.
    After the belt has stretched so that the idler lever has reached the limit of its travel, remove the lock nut on the left side of the hanger box and turn the eccentric so as to allow the pedaling chain to become slack, then set the rear wheel back far enough to take up the slack in the belt, adjust the hanger eccentric to take up the pedaling chain and replace the lock nut, If further adjustment be necessary the pulley should be removed and the idler arm advanced one gear tooth in respect to the idler arm. By advancing the idler arm one tooth, this idler mechanism has capacity to take up six inches of belt stretch, sufficient to take care of all the stretch during the life of the belt.
    If the belt has stretched so much that the idler will not take up the stretch, send the belt back to the makers: the Chicago Belting Co., Chicago, IL. to have it shortened.
    Be careful to mark the package with your name and address and write the Chicago Belting Co., telling them just what you want done with the belt.
    The belts are guaranteed by the makers and should they prove defective return to the Chicago Belting Co., for adjustment, writing them fully at the time regarding such matter.
    A wide flat belt with proper care will give good service for thousands of miles but if abused it will last but a short time.
    Do not expect adjustment on a belt if it has not received proper dressing, if it has run dry or has been otherwise abused or on one that has been repaired.
