Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: Harley 1910 Magneto Drive
    Dec 2010
    Lamoille County, Vermont
    1,147
    Default Harley 1910 Magneto Drive
    I have one of the 'timeless' Harley replicas and it is kind of a hoot. But I am converting to Magneto drive as it will make it a lot more rideable. I am also putting on an M16 Linkert... again, not 'authentic' (though who cares, it's a replica!) but will make it very rideable.
    Can anyone send me a photo/list/schematic/etc. of the internals needed to set up the mag drive. I bought one of the casting sets from Fred Lange. This includes the inner gear drive/mag mount casting. And the cover. It's very nicely made. But is bare.
    Competition Distributing has the internal parts, but I am not sure which gears, etc. to order.
    If anyone has done this conversion or can send me some info on what I need to order, I would sure appreciate it!
    Thanks and cheers,
    Sirhr
    Feb 2007
    Headingley Manitoba Canada
    408
    Please keep in the loop as I was riding my timeless this summer. A) the carb fouls the plug after a short ride B) the battery runs out quickly What u are doing is what I also need to do. I'm with u, it is just for the fun and I can let my friends ride it and not worry about wrecking a 100K machine. moose102@escape.ca Any progress here would be great.
    Ross
    Dec 2010
    1,147
    @Ross: I will gladly do that.
    I did some dismantling this afternoon and started checking parts fit. The casting will need some fettling and the lip will need to be fitted. I also have to take a bit off the flanges (see photo) to get everything to line up right.
    Stripped off the timer, removed the cover and undid the timer linkage. Took off the coil as it won't be needed any more. Also removed carb as the fuel line will have to be re-routed (if using the original carb), though in my case I am going to replace w. Linkert. After those were removed, I took off the cover and marked the gear teeth, then removed the cam gear. All straightforward.
    Here are some pictures of the inside. Next, I need to determine what gears/parts I need...
    Cheers, Sirhr
    mag 2.jpg These are the castings from Lange
    mag 5.jpg The black marks show areas that will need relief
    mag 3.jpg This is the engine after removing carb, coil, cover
    mag 4.jpg Closeup of the timing case cover
    mag 6.jpg Cam gear (from behind.) Steep ramp for timer!
    Feb 2007
    408
    Awesome followup. Much appreciated.
    Ross
    Dec 2010
    1,147
    Some more follow-up.
    I haven't been able to get a thing in terms of pictures inside a magneto case... or a parts list. BUT... spent some time on the Competition Distributing site counting teeth and playing calculator (badly as usual). I also was at Harbor Vintage yesterday and Rat let me look through an original 1910 parts book he has. Thanks, Rat!
    Among the things I have been able to confirm: I will need a new cam gear. I will also need a new cam plate (three-screw post that bolts to the crankcase). The Cam gear is 48 teeth.
    Will also need two 36-tooth intermediate gears with pins to screw into the casing.
    Where things get fuzzy is on the magneto drive gear and the magneto driven gear. The Comp Dist site shows a Mag drive gear as a 36-tooth gear. But they don't specify if this gear is the one that goes up at the Magneto? Or if it somehow pins/attaches to the Cam gear. For the gear train to work, there has to be a gear "stacked" on top of the cam gear. But I don't have a picture of the front of a cam gear. So I don't know if it is integral, or if there is a second gear that fits on top.
    In addition, I assume that the magneto driven gear (the one that should attach to the magneto) *should* have some kind of taper in the middle. Could be a separate piece, or could be cut into the center of the gear. This taper would allow the magneto to be timed by allowing the gear to go at any position on the tapered magneto input shaft.
    I have written a couple of restorers, Comp. Dist and Fred Lange (who has a magnificent 1910 on his Web site) to see if I can get some pictures. The Harley Parts book was definitely helpful, but line drawings were not all that detailed.
    The other issue is trying to figure out how the Linkert goes on so as not to interfere with the fuel dirt trap or the Magneto. Making the manifold connection will be simple... I already have the flange part done. But the spacing and intake plenum length may be interesting. Certainly will have to wait until the magneto is mounted.
    Anyway, that's the update. Below is the parts list as I see it so far. More to follow I am sure... If anyone has ANY information, photos or input, I would appreciate it. This is all just based on looking at pictures of parts and trying to reverse engineer.
    Cheers,
    Sirhr
    Parts List from Competition Distributing for ‘populating’ a Lange-Made Magneto casting set going on a 1910-type Harley Single (Timeless Replica.) This will drive a Bosch ZE1 Magneto, but would drive any similar clockwise rotating mag. The Lang replica cases have pins/gear centers that appear to be about 2” on center.
    1. Part 1000SG Gasket set
    2. Part AA 311 Stud and washer set, Intermediate gears
    3. CA 308 Magneto/Cam main gear (48 tooth) @3.125”
    4. Part DA-303 Magneto Drive Gear (assume this fits on the taper of the magneto?) 36 tooth @ 2.35”
    5. Qty 2 AA 305 Intermediate Gear. 36 tooth
    6. Part CAM-SK Screw Set
    7. K 171-10 Magneto Lever for Carb and Compression Relief
    8. BA300 Compression Relief Lever (looks like I have to fabricate the magneto advance tube)
    9. CA 310 Gear Stud Plate for Magneto (shorter than Timer/Battery plate.)
    There seems to be one gear ‘missing’ from my order. The cam gear (which is driven off the flywheel/crank gear) is 48 tooth. It sits below the level of the magneto gear train. Either that gear has a second gear machined ‘stacked’ on it. Or the Magneto Drive Gear (DA303) is used here and somehow attached to the Cam gear with a key or a pin. And a similar 36-tooth gear has to be fitted to the magneto. That gear would need a taper in it, allowing the mag timing to be set. These part numbers are from Competition Distributing in Sturgis: http://www.competitiondist.com/products.php
    Feb 2007
    408
    Stay on the trail. You got it going.
    Ross
    Dec 2010
    1,147
    Just got a parts list and invoice from Competition Distributing. Lonnie out there went through my list and got me the parts lined up.
    Here is the list he sent me:
    Cam Cover Screw Kit 19.95 19.95T
    Magneto Lever 69.95 69.95T
    Pinion Gear Nut 09-17 Singles 12.00 12.00T
    Compression Relief Lever. Fits 1910 To 1917 Magneto Singles. 75.00 75.00T
    Intermediate Gear Studs & Washers 49.95 49.95T
    Pinion Gear Fits 1909 To 1917 Singles 64.95 64.95T
    Secondary Cam Gear Fits 1909 To 1917 Magneto Singles 360.00 360.00T
    Magento Gear Fits 1909 To 1917 Magento Singles 84.95 84.95T
    Large Intermediate Gear Fits 1910 To 1912 Magneto 36 Tooth ( Req. 2) 72.00 72.00T
    Small Intermediate Gear Fits 1909 To 1912 Magneto Singles 65.00 65.00T
    USPS Small Flat Rate Box - International..or Domestic? 0.00 0.00T
    Total was around $875... which seems like a bargain considering the work that has to go into some of these bits.
    More to follow when I get the parts in hand and start the assembly.
    Thanks to the guys at Competition Distributing, Fred Lange and Mark's Magneto Service... it's coming together.
    Cheers,
    Sirhr
    Dec 2010
    1,147
    Received the package from Competition Distributing today. I'll post pictures tomorrow. But I think I have everything I need except the Mag which is out being rebuilt.
    The parts from Comp Dist. were really nicely done and the aluminum cases from Fred Lange lined up beautifully with the pins. In a world of low-grade repop parts... this is truly the good stuff.
    While on the subject... does anyone know the static timing (how many degrees BTDC?) for the '10 Magneto singles? I have no idea whether the Timeless Replicas have a timing mark on the flywheel. So I will simply re-static time from TDC and the pinion gear. But need the degree number if anyone has it.
    Cheers,
    Sirhr.
    Cheers, Sirhr.
    Dec 2010
    1,147
    Latest updates for those who have been following the conversion.
    It's straightforward, but more involved than I originally thought. I'll have another parts order for Comp. Dist. because the changes to the controls will have to be made, I think including brazing a bracket to the frame. But in for a penny, in for a pound!
    I'll have to post the photos in several separate posts as I think I am limited to 5 pictures per post.
    This is the layout in the case. The Pictures C.O. posted yesterday showed this really well! The drivetrain runs the magneto clockwise. The top gear is, indeed, tapered to lock onto the magneto and to allow the magneto to be positioned in any position.
    This is the pair of cam gears. The one on the left is the original gear that runs timer bikes. The cam is different from the magneto. The right one is the new cam gear from competition distributing.
    This is the same gears from the outside face. The left gear, again, runs the timer points. The double gear is the one that runs the magneto drive train. They have the same profile and number of teeth. The post on which it rides must be shortened (or replaced... more on this later.)
    The cam gear in its orientation in the case. The post on which it rides is to the immediate right and is held by 3 nuts. A word of warning... at least on the Timeless bikes, these are NOT studs and are not secured in the rear. Do not attempt to remove this unless you want to split the cases. The shaft will have to be shortened... but will need to be done in place.
    This shows the bore diameter of the original cam gear. It came in a 0.504" on a 0.500" shaft for a .004" running clearance. This seems like a lot... so I'll be fitting the new gear with a little less clearance. The new gear was slightly undersized and had about 0.001" taper, probably caused by pressing on the outer gear. This will be addressed below. I'd always rather get a gear w. an undersized bore!
    Cheers,
    Sirhr
    Dec 2010
    1,147
    Continuing the installation
    This is the new gear from Competition Distributing. Has a bore that is about 0.003" undersized for the shaft. And there was .001" taper, with the narrow end being where the gear is pressed on.
    The bore is easily cut with a pin hone. Don't try and cut these with a drill! Most machine shops or engine shops will have a pin hone available. Or make a set of lapping bars. I cut the bore out to .503" and it fit perfectly on the shaft, mating just right with the pinion gear. Of note, in the parts I received from Comp. Dist. I got a new pinion gear and nut. But I am not sure it's needed as the original gear is the same dimensions and profile. I am waiting for a response from them to see if they do recommend replacement.
    On to the casing... the casting will need some work. One is that as it came from Lange, it has a lip on the back. This lip probably fits the original HD cases perfectly... but is too large in diameter to fit the Timeless cases. More on that later. Also, the screws (pictured above) that come with the Competition Distributing kit appear to be 10-24 thread. The ones that go in the Timeless cases are 10-32. USE the ORIGINAL Timeless screws to put on the Lange casing or you risk messing up your right engine case! To get the original screws through the Lange casting, you will need to open up the 6 holes with a number 10 drill and countersink the holes to 5/16 +-
    In an earlier post, I showed where the casting would have to be relieved. Using a Dynafile, I ground off the interfering areas and dressed the profile. Again, may not be necessary on an original HD case, but needed on the Timeless.
    Here is the case with the flanges dressed. Now clears the cases perfectly and is nicely blended.
    More to follow...
    Cheers,
    Sirhr
