Results 1 to 5 of 5
Thread: Clutch Booster question
  1. #1
    Jul 2010
    199
    Default Clutch Booster question
    Part # 38456-52 Booster or 'mouse-trap bracket'. Attaching pictures of 2 different ones I have. One on left has a gusset on bottom, one on right doesn't, and the offset for the eyebolt is different. Also the one on left(with gusset) has grease fitting at an angle. One on right(without gusset) grease fitting is straight out. Looked in Palmer's and no mention of any change. Does anyone know what year these fit. I have several of these and only one without the gusset. Hope pictures come across,I am new at this.11.28.10 002.jpg11.28.10 001.jpg
  2. #2
    Nov 2010
    207
    The one with the angled grease fitting is a -52 one , the one on the right is a -67 one , i just went through this the other day , and i went by an nos one still in the wrapper with a -52 number that had the angle grease fitting ,
  3. #3
    Feb 2010
    143
    The one with the short arm without the gusset is 52 to sometime in 56. The longer arm with the gusset and the angled grease fitting is used for sure 57 and later,through 67. The 65-67 bell crank has nothing to do with the early or late bracket, but is only correct as a unit with the gusseted bracket.....Rod
  4. #4
    Feb 2007
    Hummelstown, PA
    901
    All the 52-54 original pans that I have photographed all show the version with the straight zerk fitting boss.
    Brian Howard AMCA#5866
  5. #5
    Jul 2010
    199
    Thanks for everyone's input. Bob #6738
