Servicars take a 96 link primary chain. Can you run a 100 link solo chain on a servi? Why the difference anyway?
Kevin,
It all depends on what motor sprocket is being used. Servi's normally run a smaller motor sprocket than a solo, thus the shorter chain.
I run a 100 with a 33 tooth motor sprocket on mine. Its kinda doggy outta the hole but cruises nice.
What's your top speed chris? And are you dogging the clutch to the point it's trashing it? I put in a 27 tooth sprocket with a 100 link chain and i had to pull the tranny back so far that i was almost at the end. And then the rear adjusters were maxed out. I'm thinking i need to re-link my drive chain. len
p.s.Didn't mean to hijack the thread. I figured it's good information to know
