Results 1 to 6 of 6
Thread: Porous engine cases
    Default Porous engine cases
    HI All - I've been told there is product out there on the market which is great for fixing porous engine cases on early antique/veteran motorcycles.
    I've been told it is a spray that is then oven cured.....
    Anyone know of it?
    thanks
    JP
    I have a few motorcycles, autocycles and bicycles
    I restore and recondition magnetos and generators - as I could never find anyone who did a good enough job.
    Dec 2006
    1,038
    Default Cheers!
    Thanks - looks like it will do the job - do most people seal their inside cases?
    Feb 2007
    Hummelstown, PA
    901
    Can't say what others do, but I seal mine. H-D sealed them during original production at least till the early 70's so it's most likely a good idea.
    Brian Howard AMCA#5866
    Mar 2005
    Huntington, New York
    363
    Harley used Gasoila for many years with good results. I've used it as well and like it, although I now prefer Glyptol (from Goodson).
    Bill Pedalino
    AMCA 6755
    1,706
    Beware that Gasoila has no resistance to modern fuels whatsoever.
    A leaky petcock on an OHV will curdle it into the oil upon sitting for any extended period of time.
    Sorry,
    It is not that there are not many fine products that have been used for generations,
    it is just that modern fuels are extremely digestive from additives designed for fuel injectors, etc., etc.
