Results 1 to 10 of 11
Thread: Tranny main bearing.
    Sep 2007
    Jersey City
    1,511
    Default Tranny main bearing.
    Can someone here give me a manufacture’s number for a early four speed tranny main bearing #9020. Found one in the shop and half the numbers worn off. Gonna try and get them though my local bearing shop. To say the least, old stock good ones. Bob L
    1,408
    Bob,
    The number on one i just looked at is MRC 305 S F F. Hope that helps!
    Robbie
    Rubone Amca #2736
    Sep 2007
    Jersey City
    1,511
    Quote Originally Posted by Rub View Post
    Bob,
    Robbie
    Thank you! Not only does my local bearing supply have them. There $2.97 a piece less than Taiwan’s wholesale.
    Mar 2005
    Huntington, New York
    363
    Are you guys talking about the large ball bearing on the main shaft on the right side? If so, that's a GREAT price !
    Bill Pedalino
    AMCA 6755
    Sep 2007
    Jersey City
    1,511
    No, No Bill. They were $17.70 each not $2.97. I wish!
    Sep 2007
    Jersey City
    1,511
    Now that I got the bearings in hand. Here’s another question I’ve always wanted to ask. When ever I install one of these bearings I always removed the seal on the gear box side. Is there any reason to have ether seal in? I mean the kicker side has just as much oil as the gear side. What deference would it make? I figure the bearing would benefit from as much oil as possible. Input please! Bob
    Canada
    267
    This topic makes no sense to me. You say no not the right side bearing but the 9020 or MRC 305) is for the right side. Then, you say you paid $2.97 each for the roller or left side main drive gear bearings each? Hell, thats 44 X 9084 rollers at $ 2.97 each? Your talkin both sides mainshaft bearings er wut?...44 rollers at 2.97 is 120 odd bucks,,,ouch!! The 9020 r/side ball bearing at $17.50 is normal...Joe
    Joe AMCA# 3435
    Sep 2007
    Jersey City
    1,511
    Quote Originally Posted by partshunt View Post
    Let me clear this up right now. What I stated was the bearings were $2.97 cheaper each at my bearing supply than one at my motorcycle parts wholesalers. As for my last post, I’m talking about the shields on each side of the bearing. I had no problem understanding it why did you?
    Jan 2008
    101
    Robert:
    I always leave the shields in place to block out any debris that may find its way into the bearing. It won't lack lubrication and the oil around the bearing will keep it cool. If you get the SS bearing instead of the FF, it has metal shields, but they are just shields and don't seal the lube in or out. Either one works fine.
    Tim
    1,408
    partshunt,
    Go back and re-read it. You seem to have missed the whole thing.
    Robbie
    Rubone Amca #2736
